G23 Discussion Thread
Being that there is already and H2B discussion thread, i'd thought it would be nice to get a G23 thread going. being that this is a newer yet very fast uprising hybrid build set up coming up. I myself have just started laying out the plans for a motor my little brother wants and i will be assembling and tuning. anyone out there with some experience with these set-ups fell free to chime in and shine some light. my little brothers build will be f23 stock sleeves with bisi custom piston rod combo and an H22 head. so far i scored an H22 head in imaculate condition for $80 and a complete F23 longblock, which we are pretty much just going to use crank and block for $150. head will be going to RLZ for a nice port job, and compression we're looking at about 13:1 car will be tuned on E85 and going with the new hondata cpr backed up with an s300. going into a 95 DX coupe. only cut doors and FAL rear 3 windows for now. we will maybe cut it up and reduce more weight later on.
i'm collecting up the parts to do it too....i'm going about it a little different way i'm going to use f22 bottom end and h22 top end then i'm going to boost it 8/10lb...i'm putting it in an 1988 perlude si ..... i all ready have two h22a4 one in my lude and one i'm going to use for parts for this build
My setup currently
F22a1 block F20b head.
Items used:
h22 timing belt.
f20b timing pulley.
f20b water pump pulley gear.
f22 water pipe using f22 thermostat no welding but fabrications.
f22 head gasket.
The block is shot but will be rebuilding soon.
it was fast at first but since the block had 280,xxx miles it lost compression.
New setup:
F20b high comp pistons 12.24 in f22 block with f22 rods
SC14 Toyota supercharger custom fabrication done from a family friend
FMI with blow off valve
that's it will post pics
Items used:
h22 timing belt.
f20b timing pulley.
f22 head gasket.
New setup:
so looks like the bisi rods and pistons combo for the F23 were because of a big demand and were done for limited and now price is back up. $1200 for pistons and rods is not in our budget right now. being that i have a turbo car in the works. so my little brother has decided to settle for k20 pistons. type-s or type-r pistons will do for now. getting a nice port job on the head. messing with the intake manifold a bit porting it and gutting it and adding a spacer. and getting probably skunk 2 pro 2 cams. hopefully we can pull out around 230-240 from the car. with the car cut possibly get it to 1900lbs with driver in it should be well into the 11's with some seat time. lets see how this goes...
Do you guys think the F22/F23 sleeves are good for an NA motor to a point, or can they handle anything? Do alot of the NA B and K guys just sleeve their blocks so they can bore it out some more or is it mainly for strength? I've seen some 300whp+ boosted F22/F23 wouldn't NA put less stress on it?
Can you have a 260-300whp NA G23 without worrying about cracking a sleeve (if you don't bore it more than 1mm over)? I'm going to build an NA motor, and option A is a sleeved H22 block or option B a G23 with stock sleeves. I think it was PirateMcFred build and he had 250-260whp with a stock sleeve G23, so seems okay but that is just one build.
you answered your own question... if PirateMcFred can do it then you can do it .... there are alot of builds out there that this is been done with turbo. so an na g23 that makes 260- 300 whp should be alright ....build it and let us know....f23/22 are cheap thats my reasoning....
I guess I will build it and see what happens.
Had that same turbo mAni lude72 cracked like a bitch fyi build truses (sp?) and itll survive
Im doing G23-2b-Turbo
Ok so heres what i got so far....
Jdm f23a from accord Stock
Jdm h22a head ferrea valves .5mm over on exh stock sized intake
Oem honda headgasket h22 tbelt
Password Jdm intake gasket
Jdm type-s cams stock gears
Arp headstuds new oem pan gasket
Kaizenspeed bs delete kit
Ap1 S2000 Oem crank pulley
Hand built turbo manifold (need to upload pics)
Sheetmetal gay Obx intake manifold
Golden Eagle fuel rail
Bbk 70mm throttle body
Aem filter dash 6 feed
Rc 750cc injectors
Bullseye Racing Super T70r turbo
Tial 38mm with custom dump
3" downpipe Tgi industries
Precision intercooler
Tial 44mm? Bov 2.5" piping
Quartersport drag H2b kit
Ls b18a transmission b16a final drive quaife lsd
Crx SiR shift linkage
Hasport mounts
Act clutch, flywheel
Gator axles
Hondata S300j ecu
Already modded water pipe plugged the oil drain holes pressed gear on wpump
Shooting for 300whp
Rc 750cc injectors
Hasport mounts
Gator axles
Hondata S300j ecu
Shooting for 300whp
These builds will last long just get a good tune you will be good. My ecu is chipped and when i did my g22 swap i had to use my f20b chip because my h22 chip would not work on take off it bogged out bad so i switched to the f20b chip. It runs just like the f20b motor i had on my eg 4dr but it has more torque than the f20b. Runs rich but its fast as hell.
the tear down of the f23 long block and h22 head will begin this coming week. along with the tear down of the 95 coupe. looking for k20 type-s or type-r pistons at the moment...
I just finished building another G23 All motor...
Stock bore F23A1 block
K20A (PRC) Pistons
Still got the balance shafts in the block but removed the belt (Had an incident with the previous G23 and the balance shaft removal kit)
ACL Race bearings
H22 Head Cleaned up ports
Type S cams
Hacked and gutted H22 intake manifold (Soon to be done: K2h with RBC intake manifold and 74mm TB)
70mm TB
DSM 560's
RMF Replicas (Modified)
3" Exhaust
US H22 Tranny no LSD
6-puck sprung clutch, Lightweight flywheel
I'll post pics as soon as I can. By the way, it's in a CD5 Accord...
K20A (PRC) Pistons
ACL Race bearings
Type S cams
70mm TB
DSM 560's
3" Exhaust
Currently this is my build using the f20b head= 85mm bore like the f22a1 that i have. I'm making a thread on my build so if interested take a look. Details and pics on it too. It's a little messy but will look a lot better once rebuild is done. Was thinking of doing my own wire tuck to it.
