ys1 lsd tranny problem
Ok h-t I need help I just put on my new tranny clutch and flywheel every time I turn and release clutch at turning angle it rattles /clicks like if my axle was broken but they are new guy at shop said some Lsd tranny do that and I can buy a kit to make it go away is this true or can I fix it easily any help is appreciated thanks
You have a clutch-pack type LSD.
The clutch plates are worn out and they need to be replaced.
The catching/clicking you hear/feel is the clutch packs loading up and releasing under tremendous pressure. The friction materials are worn past their service life and mechanically binding-- not slipping under rotational bias as designed.
Newer Helicial-Gear Type Honda LSD's don't have this drawback, but also
don't fit in the cable trans housing either.
I bought a used JDM YS1 LSD off Ebay, and a used JDM L3 Transmission with LSD.
Both clutch type LSD's, both bad.
If you find somewhere/someone who can supply the parts and/or service on these factory Honda LSD's PLEASE let me know.
My LSD has been on a shelf for years.
The YS1 LSD, I took the car apart, trans apart, put all new Acura bearings in, put the trans back together, and then back in the car.
....only to find out I had to do it all over again.
Damn thanks for the bad news lol I bought it from a guy and even test drove it before I bought it I didn't do that but it only does it on first gear turning but all other gears turning runs just fine guess I have to put my other b16 tranny on thanks for your help I really appreciate it
Thats what they do, it's the slow speed turning where you feel it. There is more tire slip potential/rotational bias correction at speed going down the road.
Well I'm going to the shop he drove it and said they can order a kit and fix it not sure what kit ill ask on Monday due to them being closed on Sundays and if I drive it like that will I damage the transmission more its my dd
I drove mine for a week and took it out. That was years ago, and the trans is great.
It cannot be good for anything on your car. traumatic shock on everything...
WOODman
May 23, 2005 12:16 PM
