b20 swap dumping fuel out header
Old Dec 3, 2011 | 07:52 PM
springs's Avatar
Icon6 b20 swap dumping fuel out header
i just swaped a b20b into my crx and when i try to start it fuel dumps out the exhaust. there is no poping or anything just cranking. it was running just fine in my other crx before i pulled it to drop in my new one. i crank it for a few seconds and there is a puddle of gas. any ideas would be helpful, thanks
Old Dec 3, 2011 | 08:00 PM
Spug's Avatar
Default Re: b20 swap dumping fuel out header
Have you checked to see if you have spark?
Old Dec 4, 2011 | 08:10 AM
springs's Avatar
is there a way i can check spark by myself?
Old Dec 4, 2011 | 08:36 AM
KINGVEM^^ED6's Avatar
why dont you have a header/exhaust mani on ?
Old Dec 4, 2011 | 08:39 AM
springs's Avatar
i do have a header on. i dont have the exhaust piping on it though. i need it running before i get the rest of the exhaust on. fuel is dumping out the end of the header.
Old Dec 4, 2011 | 08:47 AM
oh i c
well you could pull the dizzy
then have the ignition module tested and the coil at autozone thats what my problem was
when my car wasnt starting
Old Dec 4, 2011 | 08:53 AM
springs's Avatar
ill go give that a shot and let ya know
Old Dec 4, 2011 | 10:07 AM
springs's Avatar
k so the cel are 10 which is intake air temperature and 15 ignition output signal. before i go out and buy a new dizzy is there anything else it could be. wireharness is brand new ive checked and rechecked all my grounds. i checked for spark and there isnt any. plugs are new. plug wires and dizzy i was using earlyer before the swap. i know honda dizzys suck and go out all the time.
Old Dec 4, 2011 | 01:09 PM
90civic-ZC's Avatar
sounds like the ignitor in the dizzy has gone bad.....
Old Dec 4, 2011 | 04:48 PM
v4lu3s's Avatar
RTFM
code 15 can be ignitor, coil or bad ecu, or bad wiring.
90efhatch
16
Sep 14, 2011 12:36 AM
2005avtj
Aug 29, 2008 12:09 PM
luv2boost
Jul 22, 2007 05:59 PM
SuperImport
16
Apr 30, 2006 06:54 PM
RaceCobra
Oct 27, 2004 11:11 AM
