B16 vs b18
No, there is no appreciable difference. An unmodded B16 head flows negligably faster than an unmodded B18 head, which theoretically means there is slightly more high end and less low end on a B16 head. AFAIK no dyno has enough precision to demonstrate a difference. Of course, this all goes out the window the minute any head work is done.
One advantage B18 heads have is quench pads, meaning you can theoretically run higher compression without having detonation.
Bottom line: keep whatever head you have and if you want to spend money on your head, spend it on headwork rather than a new head.
Gsr head > b16 head
The only reason people 'think' b16 heads are good is because of the fact you can put a type R manifold on it.
Either way, the gsr head, valves, cams, intake, etc etc, is much better. Also it lowers compression by having a smaller combustion chamber, it also prevents detonation. I'd avoid sticking a b16 head on, its useless, plus the GSR manifold gives you a nice torque curve, epic for Daily drivin
