Trouble engaging First and Reverse.
Old Dec 2, 2011 | 05:45 PM
Solidecho's Avatar
Default Trouble engaging First and Reverse.
My car had the k20a2 swap done half a year ago and last month I blew the clutch so I went and did that myself and it was the first big mechanical thing I've ever done. I also didn't have a torque wrench so I just guessed on all the torque settings.
After doing this, the car was driving amazing like it should. Then a few days ago I feel that it was really hard for me to engage first and put it in neutral after engaging reverse. But it would be a heck of a lot easier to engage first if I hit the clutch down and put it in first at the same time. Then I went on flat land and put it in neutral, then I kept the clutch on the ground, put it in first and the car started slowly moving forward. I tried it in reverse and the car was moving backwards even faster.
So I decided to do an oil change and a manual transmission fluid change. About 1.5L of fluid came out of the transmission. The oil I used was royal purple and acura mtf, it took about 2L. But this really didn't help much, maybe a little.
Can someone please help me figure out what the issue is please, I would be very grateful. Could I need to bleed the clutch? New Synchros? Amsoil transmission fluid? Did I put the fork in the transmission wrong?
Thank you.
Old Dec 3, 2011 | 06:54 AM
apexi_rsx's Avatar
Default Re: Trouble engaging First and Reverse.
best trans fluid to use is honda or acura MTF. NO royal purple or amsoil its all junk when it comes to a honda transmission. these K series transmissions are very fragile. sounds like the clutch is not fully engaging. id try to bleed the clutch and see what u come up with. put the fork in wrong? did u try rebuilding this transmission yourself? this would be useful info for us to know.
Old Dec 3, 2011 | 10:59 AM
Solidecho's Avatar
I used royal purple for my engine oil change and I got the Acura MTF in there now but I just heard people talk about Amsoil MTF like it was miracle fluid. And the fork has to come out to get the clutch bearing out, my new clutch came with a new one so I swapped it.
But I have a feeling you're right about bleeding the clutch, it's the only thing that makes sense to me right now. I had clutch hydro problems since when I got the engine first put in, about half a year ago. But I don't remember first gear being that hard to hit in.
Please guys can I have some more responses. It would honestly mean so much to me.
Thank you.
habanerored06si
Honda Civic (2006 - 2015)
Jun 15, 2013 02:12 AM
nickelz34
Mar 4, 2012 11:25 AM
toukna
Aug 27, 2004 08:31 PM
JAP_EG6
Mar 26, 2004 01:38 PM
tegasaurus
Jan 21, 2003 08:31 PM
