OBD2 To OBD1, few questions
Old Dec 2, 2011 | 02:06 PM
rush6432's Avatar
Default OBD2 To OBD1, few questions
Ive got a 2000 civic ex as a daily with the greddy kit on it right now. Looking to tune it with the emanage. Ive got a 15g kit on the car (made for 92-95 civics) and not the 19t kit. Looking to convert the car via boomslang patch harness from obd2b to obd1. is there any specific year ecu i would need or will any 92-95 ecu work?
Im mainly converting this to obd1 so that i can tweak the fuel without having the obd2 ltft/stft get out of wack and auto-correct itself. also id like to be able to add larger injectors easily without the ecu flipping out. if i need to swap back for emissions its no big deal, i can just unplug the patch harness and swap the stock ecu back in.
As far as i know, no flashable setup exists for an obd2b ecu, is that correct?
if not let me know. ill go an alternate route, but as for now id like to tune the car to 10 psi and throw an intercooler on it and call it a day.
Old Dec 2, 2011 | 05:48 PM
mtber's Avatar
Default Re: OBD2 To OBD1, few questions
92-95 honda civic ex 5 speed p28 ecu will work just fine.
I would personally suggest using a chipped obd1 ecu and having the car properly tuned.
Read over http://www.phearable.net/tech/efibeginnerguide.html
Old Dec 3, 2011 | 01:41 AM
7rrivera7's Avatar
Last edited by builthatch; Dec 3, 2011 at 09:06 PM. Reason: commercial solicitation
Old Dec 9, 2011 | 12:21 PM
wmac's Avatar
definitely.
once you convert it to obd1, you won't need the emanage, just a good tune.
Dcaustin156
Jan 9, 2014 06:56 AM
95 iteg
10
Jun 3, 2013 11:36 AM
Jason703Racing
Feb 20, 2006 08:52 PM
2.2 teg
Oct 20, 2005 08:21 AM
