How Can I TDC? h22a4
dame way on all h and f motors. if you remove the upper timing belt cover there is an arrow that points up. make sure it is pointed up and that the two lines at the 3 and 9 o clock position are aligned with the top of the head. this is the best way.
you can also find it by using a long screwdriver in the #1 spark plug hole(first remove spark plug). rotate the engine. when the screwdriver is at its highest point the #1 cyl is at tdc
89civichb
Oct 6, 2008 09:08 PM
jdmsiR20
11
Feb 9, 2006 04:53 PM
