Which Honda type was this SPEEDOMETER from?
i bought an F22 engine which included with this speedometer
the mechanic told me this was either from Accord/Prelude
but i searched around and cant fine match speedometer
I've spent about 20 minutes searching everything Honda and Acura and can't find anything even relatively close either.
It has to be out of something JDM since it is only in KMH. It is definetly a Honda cluster though.
Whatever you have, that's a nice cluster.
How can you be sure that it's Honda? I agree that it's definitely not North American. Honda usually has the CEL and other lights above the shift lights don't they?
OP, Do you have any pictures of the back of the cluster? What car is it in were you took this picture?
i have already spend 1 whole day looking for exact same model
but still very very very corious which honda using this
its already assembled in my Honda Accord 91 sedan 2.2L
thats the problem, but its Honda, it was shipped together with engine F22, all the harness, ECU, and this cluster
everything work well, confusing
Well if it plugged right into your stock harness and the engine package came from Japan. I would say that it is a JDM 90-93 Accord cluster. Not sure that the Prelude used the same connectors. If it required a custom wiring job, then I'm not sure what it's from. It's not from an Accord though.
Looks pretty sweet whatever it's from. Although I never understood why they put a tach in an auto gauge cluster. Must be to fill up the space...
I assume it is a Honda cluster due to the font of the numbers which looks like it's from a Honda, and the gear selector, which is identical to a CB7 Accord's, but is in the centre of the cluster, rather than to the right with the fuel/temp gauges.
I'm interested to know what it is, because I really like it. It does not appear that the gauge faces are overlays either. I think it's 100% OEM, but even with my searching, I couldn't find anything similar to it.
I think I found which car this speedometer s from... Its from some kind of Acura Legend. I think your picture maybe a newer maybe jdm one though. There are similarities. Check it out:
Ah yes...I searched Acura Legends, and didn't even come across a cluster like that. The tach/speedo faces are different, but the rest of it all seems to line up.
I've got a 95 Legend at my local yard. I might look into seeing if that cluster could fit a CB.
u found it
but bad news for me
this car is not F22 (SOHC)
its F20
the seller cheated me
when the engine arrived the engine number was scracted
i couldnt read the engine code clearly
F20 is actually a better engine. It's a very common swap too. Most swaps you see in CB7s are H22 or F20. He didn't cheat you at all. You actually got a pretty good deal out of it.
Now the DOHC VTEC F20B would be a steal of a deal in place of an F22A. However, I highly doubt they tried to pass a DOHC F20B off as a SOHC F22A.
Easy enough mistake to make.
Considering that most of the F20 talk is of the F20B type. Not as many people on here talking about F20A. It's not as popular an engine in North America.
While HT is great for Hondas in general, there's better specific forums around....
As for the F20A, there's a few guys on CB7T that run it. I suppose the F20A is a good swap if you're just looking for a stock swap and not looking to build it.
89mm Darton sleeved block, Wiseco HC light weigth pistons and light weight carrillo rods installed for $2000
90-93 PT3 head (F22A6) = Free (probably pick one up for $150)
Fully loaded chipped OBD1 ECU = $50 purchase price, another $50 for all the additional components.
Total = $2100 +/- a few bucks.
So for Around $2-$2500 I will have a brand new 95mm x 89mm, 2.4L iron sleeved block with 11.5/12:1 CR. I'm sure that it will more than likely spank any tired old $1000-$1500+ H22 swap that would be lucky to put down 160hp to the ground. If it wasn't burning oil by the gallon and suffering from bad compression. Not easily fixed on an H22...$$$$!
That is the point of spending the money on an F. Why spend $800-$1500+ on a tired old 60k+ mile H22. When you could spend that same money to completely rebuild a much cheaper F series base for N/A or boost. But that is just my opinion.
all my h22s put down 170-175 whp with mileage as high as 120k miles. usually with just an intake and exhaust too. Now as far as putting down more power who knows since the H will be on a stock ecu and you will need to pay for some tuning to make that wild F work right. It still sounds like a fun engine though...
