harness question for crx dx dpfi to mpfi conversion....
Old Dec 1, 2011 | 09:39 PM
delsizzle1's Avatar
Icon6 harness question for crx dx dpfi to mpfi conversion....
well i know i posted up a thread earlier and i took some advice given to me and went to try and buy a harness off of RYWIRE.com...............
BUT!!!!!! i recieved an email letting me know that they refunded my money because they werent sure when exactly they would have more and blah blah blah,
well im am still stuck with a super ****ed up harness (wiring all ****ed up and broken connectors) and well my question to you guys is...
is there another source i can get another harness to just replace my stock one because i dont have the time to take it upon myself to re-wire the entire motor which is ( a 91 SIR1 B16a w/PR3 ecu that i bought off hmotorsonline.com for a good deal )
or if anyone has a ready harness which is ready to go pm me please open to all comments and opinions
Old Dec 1, 2011 | 09:58 PM
crx_si-r's Avatar
Default Re: harness question for crx dx dpfi to mpfi conversion....
i think you just posted this on NWP, right.
i pm'ed you. i can build you a brand new one. txt me 916-541-5266
Old Dec 4, 2011 | 03:02 PM
88efsedanlx's Avatar
Can someone here help me please? I have a 88 ef sedan lx i just converted to mpfi and obd1 I have checked my wiring and can't figure out my problem it seams to run decent at low RPM's around 3k. But if i get over that it starts like falling on its face like stops pulling it backfires and shuts off I'm throwing a code 4, code 7, code 9, and code 15. I've tried 2 new distributors and still does the same thing. Can someone please give me some idea's. Thanks for any help that I recieve.
Code 4 Crank position sensor
Code 7 Throttle position sensor
Code 9 No.1 cylinder position sensor
Code 15 Ignition output signal
Old Dec 4, 2011 | 03:56 PM
crx_si-r's Avatar
You need to re do all your distributor wires. All of your codes are directly related to it
Old Dec 4, 2011 | 03:57 PM
crx_si-r's Avatar
It doesn't fall on its face, your car is in limp mode
Old Dec 8, 2011 | 12:25 AM
Ok guys I'm only getting a code 4 when i go to get on my car it cuts out and pops really bad will not pull
Ken99287
15
Jan 7, 2011 03:25 PM
CRX_Honda
Oct 28, 2008 05:43 PM
absinthminded
Aug 31, 2008 04:48 PM
b16edcrxblitz
Sep 9, 2004 12:25 PM
HybriDNA
Feb 10, 2003 08:50 AM
