Broken thermostat ground bolt NEED HELP ASAP!
Old Dec 1, 2011 | 08:07 PM
Hybrid94Hatch's Avatar
Default Broken thermostat ground bolt NEED HELP ASAP!
I was just trying to unbolt my thermostat ground, to attach another ground to it, and sheered off the bolt...is there any other spot where I can attach this? Its just a ground correct and can go anywhere? Anyone run into this problem before?!
Old Dec 1, 2011 | 08:14 PM
crx_si-r's Avatar
Default Re: Broken thermostat ground bolt NEED HELP ASAP!
you should have another bolt on the thermostat you can connect the ring terminal to. as long as its a solid connection, your fine.
Old Dec 1, 2011 | 08:30 PM
There is another spot on the top of the housing with no bolt to it, should be fine right?
Old Dec 1, 2011 | 09:01 PM
gringo7718's Avatar
basically any bolt will do, as long as all the connections are completed.
Old Dec 1, 2011 | 09:18 PM
It worked! Thank you for your help! I had to run a ground for my vtec sub-harness
SuciaEk420
Jan 16, 2012 06:42 PM
Xathine
Suspension & Brakes
Nov 6, 2008 12:51 PM
GsDAteg
Oct 10, 2007 01:55 PM
JDM_lover03
Jul 7, 2006 09:20 PM
mark_is_gay
May 30, 2005 03:55 PM
