Can i replace this??
Old Dec 1, 2011 | 07:34 AM
EFlove66's Avatar
Default Can i replace this??
i dont know if i can or not. it's on my 1990 civic si. this whole frame and whatnot is all bent up and twisted and the front end will never allign properly unless i replace it. but it looks like its welded in or riveted. please help!
Old Dec 1, 2011 | 07:43 AM
10psiLsEf2's Avatar
Default Re: Can i replace this??
yea its all replaceable.
drill out all the welds/rivets.
Old Dec 1, 2011 | 07:46 AM
EFlove66's Avatar
how much of a process are we talking about here
Old Dec 1, 2011 | 07:49 AM
10psiLsEf2's Avatar
depends on your skills.
did i to a da and it took 2 hours just to get the old off.
good luck
Old Dec 1, 2011 | 08:36 AM
4drEF's Avatar
Keyboard Humorist
If you are just replacing #2 then it's not too bad. The radiator sits on it so it needs to ber be removed completely of just moved out of the way while you work.
Replacing #4 is more involved. Radiator needs to be dealt with as well as the bumper, fender, headlight, and all the little parts come off to get to it.
Then you just go to town with a spotweld drill bit.
Old Dec 1, 2011 | 09:17 AM
EFlove66's Avatar
this image is a life saver. much thanks. basically all that needs to be replaced is one two and four
Old Dec 1, 2011 | 09:21 AM
90efhatch's Avatar
Its not too bad to replace. I just replaced mine on my hatch not long ago. I chose to go to a junk yard and cut the front end off a car that had no front end damage. A little more work but didn't cost much at all.
Old Dec 1, 2011 | 09:46 AM
4drEF's Avatar
Keyboard Humorist
1, 2, and 4 usually come as one piece when you do a JDM front end swap
Old Dec 1, 2011 | 12:18 PM
EFlove66's Avatar
im just worrying about getting a clean stock look before i go on modifying a lot of ****
supaman111
18
May 7, 2023 06:15 AM
Bleakened
Oct 21, 2013 11:26 AM
philosofy1
Aug 29, 2007 12:58 AM
potential
May 20, 2006 08:26 PM
dogbiscuit
Mar 6, 2006 04:47 PM
