Suspension & Brakes Theory, alignment, spring rates....
what goes into slamming a 91 hatch?
Old Nov 30, 2011 | 08:29 PM
91efbluehatch's Avatar
Default what goes into slamming a 91 hatch?
been highly interested in slamming my 91 hatch.
ive read the sticky that was posted about ride quality and beefing up the spring rate.
my current setup is stock shocks with Type RS coilovers, and im absolutely bottomed out on those and cannot go lower.
i have about 1/2 in. of my tire past the fender lines.
but ive been reading around, and i keep hearing stuff about extended top hats (to increase travel) and also about inverted tie rods?
im not really looking for the Hellaflush look, i just want to be at least another inch and a half lower
what are good coilover/shock combinations as well as supporting mods?
Old Nov 30, 2011 | 10:45 PM
Default Re: what goes into slamming a 91 hatch?
nothing???
Old Dec 1, 2011 | 05:06 AM
grumblemarc's Avatar
The Grumpiest
Pics of current drop.
Old Dec 1, 2011 | 05:18 AM
2point2's Avatar
There's no right way to do 1.5" LOWER than 1/2in of your tire past the fender line.
The novelty will wear off in less than a week if it's a daily driver.
Old Dec 1, 2011 | 02:57 PM
current drop
Old Dec 1, 2011 | 03:01 PM
civexspeedy's Avatar
Looks fine to me. Lower it any more and you'll ruin a perfectly good car..
Old Dec 1, 2011 | 03:25 PM
The Grumpiest
Leave it alone and stop trying to impress your friends.
Old Dec 2, 2011 | 10:46 AM
im not trying to impress anybody but myself.
i would just like to go a little bit lower with it.
Old Dec 2, 2011 | 12:25 PM
Libertariat's Avatar
Ek Forever y0!
There is no way in hell you're going an inch and a half lower easily.
Look at Koni/GC with extended top hats and you'll need 600+lb rates in the front and 450+ in the rear.
It's going to ride like ***. But your shocks won't bottom out.
I don't know much about EF suspension, but I'm pretty sure they have an extra-special hard time when it comes to lowering them excessively.
The car is going to be dangerous that low. I don't see the allure. Your suspension geometry will never function properly at that height. The camber range will feel unpredictable in a turn.
Old Dec 2, 2011 | 12:55 PM
The Grumpiest
Just curious. Why?
Old Dec 2, 2011 | 12:59 PM
TunerN00b's Avatar
Just curious. Why?
So he can participate in this thread, of course.
https://honda-tech.com/forums/suspension-brakes-54/slammed-suspension-setups-2077238/
Old Dec 2, 2011 | 04:19 PM
https://honda-tech.com/forums/showthread.php?t=2077238
way to be a smartass..
anywho to prove you wrong sir, its personal preference.
Old Dec 2, 2011 | 04:56 PM
TunerN00b's Avatar
It might be personal preference, but you could have found all your answers in that thread. Many of those cars are close to the height you're looking for.
Just don't expect it to perform well, be comfortable, or last very long.
Old Dec 2, 2011 | 05:20 PM
well one question i had stated above was coilover options?
which ones can allows you to go a little bit lower.
Old Dec 2, 2011 | 05:42 PM
TunerN00b's Avatar
All of them. Just use shorter springs if you're out of adjustment range.
Old Dec 3, 2011 | 10:42 AM
10000K RPM's Avatar
Airbags!!!!!!! LOL
Old Dec 3, 2011 | 11:12 AM
jake12ryder's Avatar
just chop the springs mine are and mine sits on 13 in steelies and rides real smooth for a low as it is
Old Dec 3, 2011 | 01:08 PM
The Grumpiest
Very good. You just told everyone on H-T how cheap you really are.
Old Dec 3, 2011 | 01:14 PM
you sir are absolutely dumb. never in my life would i put cut springs on such a clean and fully functional car.
also your car is on steelies and cut springs, so that tells me how cheap, and quite possibly ugly your car is.
this is good enough for a quoted signature
Old Dec 5, 2011 | 12:08 PM
TunerN00b's Avatar
gtf outta here with the bags lol
bags are for ***s, or for groceries
Actually, air bags are the best way (or one of at least) to have a very low car, at least in terms of staying the most usable (can raise it for driveways / speedbumps with the right systems) and damaging the ride quality the least (very progressive spring rate)...
Old Dec 5, 2011 | 01:15 PM
Dead CIVIC's Avatar
Veteran: Army
grumblemarc< you have 9k+ posts and this is how you post on peoples threads? how are you not banned yet, you've been to help at all to this thread. I'm gonna report you to a mod.
OP. for the look/style that you a pursuing I strongly suggest going for a fully adjustable coil over setup. like maybe K sport, F2, DC, or even the famous CG/Koni combination witch i read allot of good stuff about.
Its a good look in my opinion. I have F2's but i'm not slammed yet. I'm till thinking is it worth smashing that sharp metal inside the front housings that keep cutting up my tires haha.
good luck. Oh yeah you'll spend 700$+ on coilovers or
Old Dec 7, 2011 | 08:44 AM
10000K RPM's Avatar
My airbag comment was totally sarcastic. I run PIC selects on all my cars. The op seems kind of clueless. Also i am not a noob, the wife got pregnant so i put my cars on the back burner for about a year now except starting them and a quick spin around the block. I started a new acct on here that is why i have very few posts.
Old Dec 7, 2011 | 03:10 PM
i plan on having a healthy suspension. i was thinking about k sport, or gc and koni.
im not clueless, i just dont have time for retarded comments when not needed. your personal life has no affect for me on a forum. so with all do respect i could care less.
Old Dec 8, 2011 | 11:20 AM
JDMEF's Avatar
lol just get some small *** springs dude.. ebay ones are dope for slamming but the ridequality goes to ****. no matter what if your slammed your gonna bouce alot. unless you buy expensive function and form coilovers
Old Dec 8, 2011 | 12:37 PM
The Grumpiest
I wouldn't call Function and Form expensive.
