FS in OH: 96-00 Civic parts, random F22/H22 parts
I've had this posted in the Midwest section for awhile now and thought I'd post it in the main FS thread now too.
All prices are best offer and available for pickup on the eastside of Cincinnati or up to Dayton's southside. Shipping is also available for everything EXCEPT the rear hatch panels (just too big and awkward to ship). I will try and get whatever items you are wanting into the USPS flat rate boxes to save on that. Paypal (or cash if picking up) are the only methods of payment I'll accept.
The fastest way to get ahold of me is via email (whiteacclude@yahoo.com) or text (513-253-6660). I'm only on here relatively frequently, but not every day. Please do NOT text me anytime between 10pm and 7am... I'm old and need my sleep!
I will consider trades for 1998 Civic Hatchback parts. EMail/text me with any offers and please include pictures. If out of town, email me and we can work something out.
PLEASE READ CAREFULLY -- I am only listing those parts that I have available. IF its not listed, I don't have it. I will list parts sold on here as a bit of a vouch:
- Tweeters -- ** SOLD to cruizinmax **
- carpet -- ** SOLD to IHRTJDM**
- floor harness -- ** SOLD to B18eg6ICK**
- OEM radio/tape slave and CD changer -- ** SOLD to updhands**
- b-series cam gears -- ** wtf_is_jdm**
- y8 clutch kit -- ** SOLD to Honda_ek9**
ALL PRICES ARE BEST OFFER!!!!! I can't stress that enough.....
- Suspension Techniques 22mm rear sway Bar with endlinks and subframe bushings/brackets. Was told that this would fit an EK, but its way too long. Doesn't fit a 94 Integra/DC, so I'm also assuming it doesn't fit 98+ or EG Civics/ No idea what it does fit. IF you know, LMK so I can label accordingly. -- $50 takes it
- 96-00 OEM Honda front upper control arms ***SOLD LOCALLY***
- Rear Lower Tie Bar (Will ONLY fit 96-00 Civics) - $10
- 96-00 OEM Honda Civic rear LCAs. The hub mount bushings will need replaced - $15
- 96-00 Honda Civic front driver and passenger EX brake calipers. Came off a non-ABS Civic (not sure if that matters to those with ABS or not... buyer to determine). I will NOT separate the pair -- $30
- Working windshield wiper motor - **SOLD LOCALLY**
- D16Y7 Alternator. **SOLD LOCALLY**
- Honda Passport NON-WORKING alternator. Good for a core - $5
- (2) H22A OBD1 distributors. ***SOLD LOCALLY***
- d16y7 P2E manual ECU. ***SOLD LOCALLY***
- 96-00 Civic Interior fuse box with fuses and relays. - $12
- 96-98 Engine bay fuse box (Came from an EX/y8/5spd) bare - $5
- 96-98 Engine bay fuse box (Came from an EX/y8/5spd) with fuses/relays - $12
- Various switches/buttons; (1) hazard, (2) rear defrost. All in perfect working order. - $5 each or (2) for $8
- Honda Main Relay Switch. This should fit all model 1996-2000 Honda Civics however its the buyers duty to find out. Worked perfect when removed - $20
- F22 Accord non-vtec fuel injector resistor - $10
- Ebay CAI intake bypass valve ***SOLD LOCALLY***
- 1996 Honda Civic Driver's side airbag. ***SOLD LOCALLY***
- 96-98 Civic SRS brain. Buyer to determine if it works on 99-00 Civics as well. Removed from car with no front end damage. - $20
- Rear view mirrior - $3
- 96-00 Civic Cluster bezel - $5
- d16y7 Clutch, pressure plate and flywheel. **SOLD LOCALLY**
- d16y8 Postive battery cable and starter wire - $5
- d16y7, d16y8 and possibly other d16 motors, upper and lower radiator hoses. No rips, cracks or tears. Just replaced with new ones at the time of the swap. - $5
- 96-00 Civic (and possibly 92-95 Civics and 94-01 Integras) Edelbrock Short Shifter -- ***SOLD LOCALLY***
- 1996 Civic EX Cruise Control Unit. Worked when removed. May fit other makes (Integra?) and Models (Accord? CRV? Prelude?). It's the buyer's responsibility to find out compatibility. - $10
- 96-00 5spd clutch line that runs from clutch reservoir to the soft line behind the block - $5
- 96-00 5spd clutch line (soft and hard line) to the CLutch slave cylinder. Boot in good shape. Worked fine when I swapped in the y8/Tranny into my car. -- $15
- Various motor mounts from b18, d16y7, d16y8 and d16z6 motors/cars. Bolts will be included if they are shown with the mount. $5 each
- D16Y7 header heat shield. In good shape for its age. No busted bolt holes. Good candidate for a re-paint - $8
- 96-00 Civic Power Steering Reservoir and hoses - **SOLD LOCALLY**
- 96-00 DX/LX tranny flywheel cover - $10
- 1996 Honda Civic EX Brake Booster. ***SOLD LOCALLY***
- D16Y7 & D16Y8 OEM Honda oil pan. ***SOLD LOCALLY***
- Autometer Pro-Comp Air Fuel Gauge. ***SOLD LOCALLY***
- 96-00 OEM Honda front upper control arms***SOLD LOCALLY***
- BNIB Autometer gauge angler pod thingees - $5
(also have those sub box tubes pictured if someone is interested)
- Rear bumper foam/reinforcement -- JUNKED--
- Windshield cowl with all snaps/buttons/thingamjigs. No cracks at all and in great shape - $15
- Rear dash/speaker cover/panel - $10
- driver and passenger side panels from a 96-98 Hatchback. May fit 99-00 hatches as well, but that is for the buyer to determine. Dark gray color. Normal wear but no significant scratches and no cracks. WILL NOT SHIP - $35
- Front undercar splash guard/wind panel. No tears. - $15
- 96-98 Coupe A-pillar plastics. ***SOLD****
- 96-98 Hatchback rear trunk trim -- JUNKED--
- 96-98 Coupe rear trunk trim. -- JUNKED --
- 96-98 Rear Hatchback speaker covers. May fit 99-00 hatchbacks but for the buyer to determine. All clips present for the cargo cover. No cracks. Hard to find in this good of shape. Will not separate. - $30 for the pair.
- 96-00 Civic driver door window glass. ***SOLD LOCALLY***
- OEM 92-96 H22 oil pressure sending unit. Pulled this from a motor I built a few years ago. Worked fine when pulled, but removed to put in an Autometer oil pressure gauge. Might fit 97+ H22s, but up to the the buyer - $5
- (1) OEM Honda H22 tensioner stopper, Honda P/N: 14540-P13-003. BNI-packaging (used-once tensioner ***SOLD****) . - $5 each
- BNIB d16 Thermostat. Stant P/N: 13878. Does not include gasket (which is sold separate at any parts store). $8
- BNIB Beck/Arnley Distributor cap, P/N: 174 7007. ***SOLD****
- BNIB Airtrex electric in-tank fuel pump, p/n: E8335. Fits most Hondas, but click the Summit link below for more applications. Buyers duty to check fitment before purchase. - $50
More info and Summit Racing's price here: Airtex 110-E8335 - Airtex Electric In-Tank Fuel Pumps - Overview - SummitRacing.com
- BNIB Fel-Pro B18A, B18B cam shaft seals. $8
ALL PRICES ARE BEST OFFER -- Don't like a price, make me an offer. The worst I can say is no.
I live on the eastside of Cincinnati and work in Dayton. Texting me will be the fastest way to get ahold of me.
Both H22 distributors ***SOLD LOCALLY***
Taking all lowball offers. Really need the space. will consider trades for an OEM or aftermarket axleback muffler for a 94 Integra coupe (Just picked up the winter beater and it needs the muffler... cheaper the better). Email or text me offers.
Yup... it's in the 6yh picture down, with the y7 clutch:
I appreciate the bump. Thaks for the purchase!
Been a while bump..... Updated the Sold list too. Shoot me offers... need the stuff gone. Heck, lowball me, you might be surprised.
