SCREWED UP RADIO ANTENNA
Well guys I knew it when I pulled it out but TOO LATE! DUH!! Have a 90 Civic sedan and the antenna broke so I got a new one and pulled the old one out without attaching something to it so I could pull the new one back in. Now when I feed the new one down the pillar, it gets almost to the bottom and is getting hung up on something. It is SOOO tight in the kick panel to get my hand in there to find the hole it comes out of to try and grab it but can't seem to get in there. Anybody have any suggestions on how to fix this? Thanks.
Thanks for suggestion but I can't seem to see where the antenna cable comes out at the kick panel. Too confined and crowded. I have fished it down from the roof where it mounts but right about where it hits the bottom of pillar it gets hung up.
i just did mine recently and i dropped my hhood release and main relay out of the way and used my freakishly long middle finger to pull it through ....not to hard to do ....but if you have cocktail weenies for fingers use a coat hanger
r3sistance
Mar 16, 2008 08:43 AM
