Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Popping noise when I accelerate
Old Nov 30, 2011 | 10:21 AM
Masho's Avatar
Default Popping noise when I accelerate
Yea, when I move my car forward, I hear a brief popping noise. I'll be at a complete stop, then the instant my car moves forward I hear that damn pop, and it's coming from my front right wheel I think.
Did I get something caught in my wheel or something?
Does anybody have any idea of what it can be? Thanks in advance.
Old Nov 30, 2011 | 11:39 AM
ES1TopGun's Avatar
Default Re: Popping noise when I accelerate
https://honda-tech.com/forums/honda-civic-2001-2005-78/frontend-knocking-no-visual-problems-3002692/
Maybe this will help a bit
Old Nov 30, 2011 | 11:47 AM
Dc4LsTeG's Avatar
EK9
I'd say ball joint,axle, or tie rod..Jack your car up and do a visual inspection on everything
Old Nov 30, 2011 | 01:48 PM
briangartner's Avatar
Had a very similar issue with my 01, turned out to be the larger of the two bushings on the lower control arm. You should be able to inspect that bushing by looking thru the space between the tire and the bumper.
Old Nov 30, 2011 | 05:18 PM
toyomatt84's Avatar
Sanji
That is the compliance bushing. It is a very common wear item on this chassis (and is also discussed in the link provided above).
Old Dec 6, 2011 | 06:25 PM
delta10's Avatar
always check the axle first. but its something in that general area it sounds like.
Old Dec 6, 2011 | 08:15 PM
lazlong's Avatar
If you're not getting vibration/shock from the pop in the steering wheel then check your motor mounts.
refpoman
Nov 17, 2013 04:09 AM
k20eklipse
Aug 3, 2010 08:40 PM
93CharcoalHatch
13
Mar 23, 2006 03:10 PM
rudeman85
Oct 27, 2004 02:52 PM
alb_accord
Mar 26, 2004 05:41 AM
