How to separate 2pc inner hub from brake rotor-disc
Old Nov 30, 2011 | 08:27 AM
regnevazota's Avatar
Icon2 How to separate 2pc inner hub from brake rotor-disc
90-97 Accord
I read the FAQ on for the 90-97 front brakes. But I dont think anyone is looking at that anymore for the purpose of answering questions, so I deleted my question at the end of the FAQ to post it here.
How did you separate the rotor/disc from the two piece inner hub assembly after you get it off of the control arm area? Does the disc just come right off easy then? ... Do The gold colored hex head bolts that are recessed in the outer rotor face get removed in order to get the disc/rotor off? Is there any precautions with the inner bearing(s) coming apart or is it a one piece unit as it appears to be in the HSM?
Old Nov 30, 2011 | 08:29 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: How to separate 2pc inner hub from brake rotor-disc
i remember we used a big slede hammer to take it off, but you have a risk of damaging your wheel bearings
Old Nov 30, 2011 | 09:36 AM
v4lu3s's Avatar
RTFM
99% of the time once you remove the hub from the bearing you will need new bearings. might as well just budget for them.
the slide hammer, a sledge hammer or a press will be what you need to separate the hube and bearing.
Old Dec 10, 2011 | 01:14 PM
I'm not trying to separate the bearing from the hub.
I want to get the brake rotor off the hub, so I can install new rotors.
Old Dec 10, 2011 | 02:59 PM
7azhar7's Avatar
haha I did this job early this year. I put in slotted drill rotors. you basically need a hub puller. you can get from auto-zone. its a talon grip that grips behind the rotors while screwing the middle to pull it out. then the 4 lug on the front separates the rotor and hub.
Old Dec 11, 2011 | 07:02 AM
Lost Again's Avatar
Confused, if you have the hub, bearing and rotor off the car????
The bearing does not have to come off to get the rotor off.....of course the four bolts going thru the hub into the rotor have to be removed, then it will either fall off or a tap with a big friendly hammer and done.
EDIT: search for this 5xIUAMl-oRQ
Old Dec 11, 2011 | 07:31 PM
Hairnandez's Avatar
or you can get the Rotor over hub off of other cars like my 99 2.3 CL which i happen to have laying around
soon2bdropped
Apr 22, 2007 06:39 AM
blueDAteg
Mar 25, 2007 10:25 PM
DOHCRAZY
May 26, 2006 06:13 AM
PAID-$$$
Jul 26, 2004 08:27 AM
Mattyk
Mar 30, 2003 10:59 AM
