Crower cams
Old Nov 29, 2011 | 03:23 PM
Gsrsi's Avatar
Default Crower cams
How safe is it to buy used cams, what's should I look for. They are crower cams stage 2 for n/a. Part number 63402. With skunk 2 cam gears.
Old Nov 29, 2011 | 03:35 PM
mark@silbernage's Avatar
Default Re: Crower cams
Looks for signs of wear, both on the bearing surfaces but especially on the side of the lobe that does the lifting. Signs of abnormal wear would be scuffing and especially scratches, flat spots - anything that says too many miles, improper installation (spring bind / excessive pressure), running out of oil, etc.
The surfaces will be smooth and shiny with normal wear, but should not show flat spots, scratches, or galling (roughness due to lack of oil or excessive pressure breaking down the oil barrier).
Old Nov 29, 2011 | 04:16 PM
Gsrsi's Avatar
Thank you. Any opinions if I should run a b16 head with this.
Gsrsi's Avatar
I have a 99 b18c1
Old Nov 29, 2011 | 04:42 PM
mouab18c1's Avatar
Whats wrong with the gsr head?
Old Nov 29, 2011 | 04:51 PM
GagnarTheUnruly's Avatar
Keep the GS-R head unless there is something specifically wrong with it
Old Nov 29, 2011 | 05:59 PM
Gsrsi's Avatar
Nothing's wrong so ill keep it but, I was trolling on the crower website and i figured out there older cams. The ones they sell on their site currently are 63402-2. These are 63402, anyone think that matters? I asked him where he got them from and he say he's had them for a couple years.(my sense figuered that since he didnt put the -2 that they are older) also should my engine have any thing specific on it? i have a hytech header, 3 in exhaust(the b16 i had in the si was turbod should be picking up a 2 and a halfer soon) apexi tip,stage one clutch and a pwjdm power chamber aka whale *****. they are 3/4 race cams.
Old Nov 29, 2011 | 06:06 PM
doood's Avatar
been there done that
you're gonna need an upgraded valvetrain
Old Nov 29, 2011 | 06:12 PM
Gsrsi's Avatar
hmm thinking about buddy club or itr any opinions?
Old Nov 29, 2011 | 06:31 PM
You should plan on upgraded valve springs for any cam upgrade, although some people get away with GS-R springs on ITR cams.
I would ask around about running those Crowers on 10:1. I suspect you don't have enough compression and will be over-cammed. It might be that stage 1 are a better choice.
Also, make sure you have a tuning solution otherwise you won't really see any advantages to those cams!
Old Nov 29, 2011 | 07:30 PM
Gsrsi's Avatar
don't you want higher comp for a n/a motor? i don't really know too much about cams.
Old Nov 29, 2011 | 07:38 PM
mouab18c1's Avatar
He is saying your stock gsr compression might not be able to support the Crower cams. Which in other terms would be over-cammed.
For N/A I prefer to be anywhere from 11:1-12
Old Nov 29, 2011 | 07:42 PM
Gsrsi's Avatar
So can I just use a different head gasket or should I invest in some hc pistons
Old Nov 29, 2011 | 07:44 PM
doood's Avatar
head gasket should be your last option when trying to affect compression
Old Nov 29, 2011 | 08:28 PM
mouab18c1's Avatar
If you want to stay with stock pistons then use either p73 ITR pistons or b16 p30 pistons.
Old Nov 29, 2011 | 09:37 PM
Raising compression is worthwhile if you're doing an NA build, but expensive. If you're getting to the point of spending that much money unnecessarily (i.e. when you aren't doing a necessary rebuild). If you go that route you should carefully consider your ultimate goals for your car. For most people turbocharging is probably a better choice.
But if you don't want to mess with rebuilding your engine, cams are still a good choice. A completely stock engine can easily run ITR or stage 1 cams. I have Blox As. I have a feeling they would be better with higher compression, but they are still entertaining
Old Nov 30, 2011 | 04:20 PM
Gsrsi's Avatar
U guys really think I will get over cammed(I plan to take it to a import shop and have it tuned and timed
Old Nov 30, 2011 | 04:39 PM
I don't know for sure. I would recommend asking or searching the all-motor forum to see what is best to run for 10:1 compression. Those guys know their stuff.
Old Nov 30, 2011 | 05:20 PM
Gsrsi's Avatar
Thanks I appreciate every ones thoughts.
Old Dec 1, 2011 | 05:44 AM
kyden's Avatar
i would stay away from crower brand cams. in the past there have been issues with the cams snapping in half. i've had good luck with brian crower cams though.
Old Dec 1, 2011 | 06:20 PM
dc2_Dai's Avatar
if ur getting them just get em new, had stag2 in my 01 itr block loved it then and i had stag3 in my gsr head work fully done, loved it even haven't felt another cam that felt as good
Old Dec 1, 2011 | 07:36 PM
I'm running Brian Crower's 63413 cams in mine - love 'em. Even idles nice.. ; ' )
Mark
SiR-iNTEGRa
Mar 2, 2012 01:20 PM
93itbh22hatch
34
Feb 7, 2011 02:14 PM
kulo
Dec 7, 2009 09:23 AM
IamVtec
Jul 6, 2009 06:01 PM
Boarderx192
Oct 12, 2004 09:27 AM
