Detailed Description Of Clutch Problem. 1990 EF B18
Old Nov 29, 2011 | 02:23 PM
ThaEfSwap's Avatar
Default Detailed Description Of Clutch Problem. 1990 EF B18
Hey guys, so every check my car likes me to put money into it and this time I have a clutch problem but I don't know. Basically, my clutch has a 'sticky' feeling. When I am in first gear, take it passed 4500 and drop the clutch in second trying to chirp my gear, the clutch doesn't grab right away, but it doesn't slip either.
What I'm trying to say is, it'll go first gear, 6000 rpm, shift, drop out clutch and have gas on (revs up like clutch is still in) then it'll grab hard after half a second and chirp....
I'm going to go mess with my clutch cable... but I know it won't satisfy me.
HOWEVER! driving normal and shifting at 3000 rpm or less is perfectly fine lol.
P.S Sound effects before and after:
Before: 1st: vwam, BWAHHHHHHHHHHHH *shift* 2nd ERRRR BWAHHHHHHHHHHHHHHHH *shift* third CHIRP BWAHHHHHHHHHHHHH
after: 1st: Vwam, BWAHHHHHHHHHH *shift* 2nd clutch stuck RINGGGGGG er, BWAHHHHHHHHHHHHHH *shift* 3rd RINGGG BWAHHHHHHHH
Old Nov 29, 2011 | 02:37 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Detailed Description Of Clutch Problem. 1990 EF B18
Sounds like a worn clutch disc that slips and grabs when the flywheel is spinning at high RPM.
Grabs right away when at low RPM.
Might be just a slight cable adjustment, but if that doesn't fix it then I think you're going to be taking it apart.
Old Nov 29, 2011 | 03:49 PM
ThaEfSwap's Avatar
LOOOOOL my floor mat was holding black the clutch petal lmao
Old Nov 29, 2011 | 06:33 PM
crvtectim's Avatar
Way to go, n00bcakes!
Old Nov 29, 2011 | 06:37 PM
usdmsol's Avatar
hahaha this happened to me before
lokodog
Dec 25, 2005 09:39 PM
japhonda
13
Jul 30, 2005 01:19 PM
_Endless_
Sep 4, 2004 02:46 AM
pbizzlegsr
Sep 2, 2004 07:36 PM
petrv
Aug 17, 2004 02:10 AM
