Front Facing Turbo Manifold on EG?
I like this manifold for Drag racing but don't know if I need to buy one specially for EG Hatch or all Civic are the same long as there is a B series engine?
Do I need to change my Front Bumper or have to cut it?
For Drag Racing is this Manifold really good? Isn't too many length of tube before the Turbo?
A picture would be great of the mani. The only clearance issues I have faced is the hood, A/C and the bumper support areas. Just be sure to check clearance for where the turbo will sit in relation to those items mentioned. Also when doing measurements make sure if the turbo is clocked that it still fits, that is if you need to clock it.
Depending on where the inlet is run or how you run it, you might lose the headlight or, yes you will have to cut a hole in your bumper. Are you looking to have an 8sec car, or just drag it and run 13's?
You have to also run a custom intercooler in order to that front facing turbo. Its mainly used for those with one piece front ends (dedicated track only) and those that want that "special look". but really it won't make anymore power
Call up afi. They can tell you what chassis they fit in.
But I have a friend with an ef 4dr with the ago foward facing manifold and 35r and it fit very nice with the stock bumper. Also have a friend with an ek hatch with the same manifold and and and BW366xl. It fits with just modification to the radiator support on both cars.
Also the ek has one of afi's intercoolers made for this manifold. So call them up!
Don't quote me on this but don't you need to **** the radiator as well? Or well move it?
One of my customer's cars:
This is centered off an AFI Forward-Facing Manifold, T4 35R, (2) MVS. Everything bolts up in the normal locations, no need to move radiator, etc...but a traditional off-shelf intercooler will not work. You're best off either contacting AFI, or purchasing a core and having endtanks fabricated.
You will need to trim the radiator support quite a bit, specifically near the frame rail..and the only traction bar I was able to get fit, in terms of a decent amount of clearance for the downpipe and dumptubes was from Tom @ NRG Tech.
My customer does drive this on the street, and we were able to fit a bumper as well. Practical? I'm honestly not sure...but it is pretty neat
Cool lookin' Joel. But I had to also remind Steeve_Civic that if he doesn't do a custom Intercooler, he'll need to get one as a kit through AFI.
Heres a good friends car i did. Its actually a daily driver, he drives about 100 miles a day ( HKS mushroom filter instead of Stack). All fits behind stock bumper and intercooler is even centered
EDIT: Found one that will help
The front mounted turbo setups are streetable, but due to their low mounted turbo position, it will increase the tendency for the turbo to burn oil and smoke.
I never had any oil smoking problem until I went with a front mounted turbo setup on the same turbo (same GT40R I had for several years). On the streets, it was totally fine, as well as during drag racing at the strip. But the moment I take the car onto the roadcourse with braking/cornering G's, or even a spirited drive and nailing some hard corners/braking/etc.. the turbo would puff smoke under G forces besides going in a straight line.
My setup already has the turbo mounted as high as possible as well (similar to what Evo1 posted).
Cool setup nonetheless, but it's really reserved for strictly straightline racing. Besides that, I do enjoy the power difference especially on the highway at 100+ mph. This was my first ever setup that I would actually hit the boost cut after I've tuned the car on the dyno under heavy load. This setup would achieve 3-4+ PSI on top of what I had dialed in on the dyno. My old ramhorn, topmount, etc.. could never do that. Having the turbo in the frontal area of the car does definitely help with performance at the top end.
It's also quite a bummer that I cannot roll into my local car wash. The car would stall out and never again, I would take the chance of hydrolocking my motor. I'd hate to be inside a car wash to remove a silicon coupler and dump out any water that has entered the turbo...lol
[img]
[img]
Nice setup Tony! It looks like you where able to use an off the shelf intercooler also. Cimburke23 is a good friend of mine here and he did the same thing but used a precision intercooler. How much of a difference did you notice in spool time going from the ram horn, top mount, and front mount?
Also to the OP. If all you want is a 10 second car and drive it around a whole lot then all you would ever need is a top mount. Hell you can easily do that with a ram horn and still run a filter on the turbo. It's your car and in the end it matters if you are happy with it.
P.S. It does look bad *** with the turbo inlet sticking out the front
You bought the AFI manifold like this?
Where do you buy your "aluminium Intake"?
Reasons to me why its not the most practical, no matter how cool it looks. But if you're in a straight line race, its awesome, if you can get it to fit.
Did you use any type of oil sump for this setup?
