F/S: Omori Boost Gauge, Misc D/B Series Stuff
-Omori 52mm mechanical boost gauge. SOLD
-Gorilla Acorn wheel locks. These are (2)two sets of Gorilla Acorn wheel locks with keys. They are durable steel with a zinc coated finish in 12mm x 1.5 thread pitch which will fit a wide variety of manufacturers, including most Honda, Acura, Toyota, Lexus, Mazda, and Mitsubishi. They are for use with wheels that have a 60 degree conical/taper seat lug flange, so they won't work with wheels that have a ball seat lug flange. Protect your wheel investment with a set, or use both sets for added security. Make an offer on one or both sets.
-19mm extended lug sockets. These are (4)four extended lug sockets that came with a set of Advan wheels I had a long time ago. They work with 19mm(3/4") lug nuts, and their long reach is good for reaching into recessed lug flanges to give more clearance for your lug wrench and avoid scuffing or scratching your wheels. They're also good for use with extended wheel studs since you can keep one or more in your car for emergencies without having to carry arround the extended 19mm and ratchet from your socket set. The ends are made to work with standard 19mm sockets and lug wrenches, as well as a 3/8" ratchet. Make an offer on one or all of them.
-Civic/Integra EVAP canister and vent shut valve. This is an EVAP/Purge system charcoal canister and vent shut valve from a 99 Integra GSR, but it should fit most OBD-II Civics(96-00) and Integras(96-01). The vent shut valve is the same part number for EX(D16Y8) Civics and RS/LS/GS/GS-R/R Integras. The canister is the same part number for the Integras, but it has the same fittings and looks almost identical to the D16Y8 canister. The vent shut valve has been tested and works perfectly. A short section of hose that connects to the line from the fuel tank is also included. Make an offer
-D16Y8 backup light switch. Off a 97 Civic EX. Make an offer
-D16Y8 engine mounts - D16Y8 driver side bracket(on block), front tranny mount, upper tranny mount(on chassis), rear chassis mount(this one might be from an LS, but I think they're the same); make an offer an any or all
________________
Buyers pay all shipping costs, if applicable.
I accept PayPal payments from verified accounts, and I ship only to confirmed addresses associated with those accounts. Cash is accepted in person, of course.
I am located in San Jose, Cali.
You can look up people I've done business with in my old F/S threads.
Thanks for looking.
________________
Thanks for looking.
inspyral
Northern California (Sales)
Jan 21, 2012 08:48 PM
