Will B18A1 automatic trans reverse gear work in a B18B1 Trans?
My reverse gear went out on 1994 Integra LS daily driver with a B18B1 and auto trans and I have a B18A1 Auto Trans laying in the garage. I just wanted to know if anyone knows if the gears will interchange before i tear everything apart. Thanks guys.
No thats not the question.... I have 2 auto trannys.... one from a B18B1 and one from a B18A1.... The reverse gear is screwed up in the B18B1 auto trans. My question is can I remove the good reverse gear from the B18A1 auto trans and put it in the B18B1 auto trans? Hope that clears up my question.
^^i don't think that would work. auto transmissions are a lot harder to interchange than manual, being that they're electronically controlled. plus i think the mounting may be different
auto, automatic, b18a1, controlld, electronically, flywheel, gear, honda, make, manual, motor, revers, tecknalage, transmision, transmission, work, works
