f22b2 timing question
Old Nov 27, 2011 | 10:29 PM
j4s0n1337's Avatar
Default f22b2 timing question
I'm replacing a bent valve in my 95 sedan and when I went to take the head off I forgot to set the cam gear to TDC -____-
I know the f22b2 engine uses 2 timing belts, if I set the cam gear and crank pulley to tdc should I be alright?
Old Nov 27, 2011 | 11:34 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: f22b2 timing question
AFAIK the B2 has the same markings on the cam sprocket as the B1, a big ole arrow and two dash marks to line it up on the head. Follow the timing belt write up and you should be fine.
SPOOLINmatt
Jun 28, 2009 04:56 PM
crxblues
10
Apr 9, 2009 10:00 AM
civiccoupe94
Jan 11, 2008 07:08 AM
shit
Jun 9, 2007 12:17 PM
I8ayellowcrayon
Dec 27, 2004 07:51 PM
