HELP!!! d16z6 cant fit rear mount. why???
Old Nov 27, 2011 | 05:51 PM
hmonkey86's Avatar
Icon2 HELP!!! d16z6 cant fit rear mount. why???
i need your help
Today, i was swap motor to my CRX.
d16z6 with hydro tranny. i want to why it cant fit rear mount?? what i doing???
Old Nov 27, 2011 | 05:58 PM
hmonkey86's Avatar
Post HELP!!! D16Z6 Motor to CRX
Originally Posted by hmonkey86
i need your help
Old Nov 27, 2011 | 06:17 PM
v4lu3s's Avatar
RTFM
Default Re: HELP!!! d16z6 cant fit rear mount. why???
did you use your crx rear mount bracket?
Old Nov 27, 2011 | 06:28 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Huh? It helps to search...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/newb-kinda-but-need-some-help-d-series-hydro-trans-my-ef-2997078/
http://www.hondatuningmagazine.com/t...p/viewall.html
http://www.d-series.org/forums/trans...d-chassis.html
http://ef-honda.com/ben/EFswapguide.html
That's just the beginning...
Old Nov 27, 2011 | 06:31 PM
marc_b16turbo's Avatar
yah cuss the on from civic of the same year of your motor wont fit
Old Nov 27, 2011 | 06:50 PM
hmonkey86's Avatar
this is really help me alot. what about axles?? it can crx axles fit to d16z6 motor??
Old Nov 27, 2011 | 08:00 PM
DO IT ON ALL FOURS
Axles don't go into the engine? The cups will fit into the transmission if that is what you are asking...
Old Nov 27, 2011 | 08:26 PM
hmonkey86's Avatar
it should be fit it. i will work on it again when i get hasport mounts. anyways, what you think i should get crx hydro whole mouths or EG mounts??
Old Nov 28, 2011 | 01:26 AM
Probably EG mounts would be easier to get.
Old Nov 28, 2011 | 10:56 AM
all-motor-crx's Avatar
you have to get crx hydro mounts
Old Nov 28, 2011 | 11:17 AM
4drEF's Avatar
Keyboard Humorist
what you think i should get crx hydro whole mounts or EG mounts??
Your car is a CRX, right?
So why on earth do you think getting mounts for an EG would be a good idea?
Call HASport.
You need mounts for a CRX to put in a D-series hydro tranny.
... and you don't need 2 posts to cover this.
It's basically the same question you are asking in your other post so pick one post or the other.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/help-d16z6-motor-3002914/
Old Nov 28, 2011 | 01:27 PM
Vinsanity88's Avatar
EFDH2 from hasport are the mounts you need. The mounts are about 299.99 and then get the Hydraulic actuator unless you want to go with Suja1 or Hush22 Performance. I've got the actuator. It's good to start out with. I'm planning on converting to the 89-91 crx pedal assy and doing the Hush22 full hydro setup in the spring. Good luck and Enjoy the new setup!
Old Nov 29, 2011 | 06:36 PM
hush22's Avatar
^^^ like
Old Nov 29, 2011 | 09:27 PM
alex14's Avatar
oh
my
god
Learn to English
Old Nov 30, 2011 | 12:36 PM
TearSDMF89dx's Avatar
Old Nov 30, 2011 | 02:52 PM
gnxpro24's Avatar
you can use your stock mounts but you also have to use the stock crx postmount on the z6 engine block
Old Dec 4, 2011 | 11:44 PM
hmonkey86's Avatar
thank you for helping everythings. i got HASPORT EFDC hydro mounts complete. it was sucess motor with hydro mounts. it was my first time make cable to hydro tranny. it look real SEXY hydro tranny. i like that. LOL
Old Dec 29, 2011 | 03:05 PM
bsmith<3ef's Avatar
is there a reason that my hasport mounts for my 94 z6 wont fit on the hydro tranny? the bolts are to small for the tranny
Roman Dolya
Sep 22, 2016 10:26 PM
SmogTech01
May 22, 2007 12:55 PM
legron_m
Jan 30, 2007 10:21 AM
fernruffryders
Oct 3, 2005 10:58 AM
xXx Justin xXx
May 16, 2002 05:27 PM
