gsr tranny wont go from 3rd to 2nd helllppp
Old Nov 27, 2011 | 11:40 AM
civicef990's Avatar
Icon2 gsr tranny wont go from 3rd to 2nd helllppp
so i got gsr tranny in my car with a b20 swap....the car always did this from the day i got it and now i just want to fix it
it will go from 1st to 2nd just fine but if u try to down shift from 3rd to 2nd it wont go in at all....the only time it will go into 2nd again is if you slow down to like 5mph and the put it in 2nd
thanks in advance for the reply
Old Nov 27, 2011 | 11:42 AM
civicef990's Avatar
Default Re: gsr tranny wont go from 3rd to 2nd helllppp
my shift linkages are good to no problem there
Old Nov 27, 2011 | 12:07 PM
grumblemarc's Avatar
The Grumpiest
What car is this in?
Old Nov 27, 2011 | 12:51 PM
jake[eh2]'s Avatar
i would say that the syncro is smashed there or something car the syncro's are what slow down the gears in the tranny to put it in gear i had the same problem in my d series try to double clutch it because that will slow down the gears enough to put it in gear if its the syncro.
Old Nov 28, 2011 | 05:04 AM
civicef990's Avatar
is in a 2000 honda civic
Old Nov 28, 2011 | 05:06 AM
civicef990's Avatar
i would say its the sychos too but it has no problem going from 1st to 2nd
Old Nov 28, 2011 | 07:17 AM
kmoua's Avatar
Lmk cause my car is just like it too! Ahahah
Old Nov 28, 2011 | 08:56 AM
The Grumpiest
Sounds to me like the transmission needs to be dropped in any case.
Old Nov 28, 2011 | 11:08 AM
civicef990's Avatar
yeah i figure that... just thot i ask maybe it could b fix with out dropping it
Old Nov 28, 2011 | 11:27 AM
The Grumpiest
Don't see HOW that would be REMOTELY possible.
Old Nov 29, 2011 | 09:03 AM
civicef990's Avatar
There are two bolts (with washer/spring and ball) my tranny someone (the owner b4 me) put the bolt in there with no washer n smashed the ball and spring in the bolt n problem fixed..
Old Nov 29, 2011 | 09:06 AM
civicef990's Avatar
There are two bolts (with washer/spring and ball) like on the post above NO!! i didnt have to drop the tranny to fix it i just replace that one bolt the had the spring and ball smashed in and fixxed!!!!
Old Nov 29, 2011 | 09:10 AM
The Grumpiest
Excellent! Glad you fixed it!!! Not that I have a clue what it is you're trying to describe.
Old Nov 29, 2011 | 12:26 PM
civicef990's Avatar
Old May 18, 2013 | 12:01 PM
jdmkid2012's Avatar
Icon2 Re: gsr tranny wont go from 3rd to 2nd helllppp
what are those ball spring screws called ????
Zakaria Ism
Transmission & Drivetrain
Apr 26, 2016 07:51 AM
jordan_rael_420
Oct 18, 2010 04:57 PM
fast2camciv
Jul 29, 2007 02:16 PM
ek_b16
Dec 10, 2006 10:19 PM
ChillOutWayne
Jul 31, 2004 10:35 PM
