Breathing filters
Old Nov 26, 2011 | 08:00 PM
Krator's Avatar
Default Breathing filters
What kind of masks do you guys use to protect yourselves from the welding fumes?
Just wondering. I heard stainless steel can be nasty on your health. What you guys say? Or is it just aluminum and brass that you use a filter mask?
Old Nov 27, 2011 | 06:35 AM
MadMax2JZ's Avatar
Default Re: Breathing filters
I use this one at work. The only time I use it is if I'm welding brass, galvanized, or any other metal that causes metal fume fever. My job is primarily welding stainless and the only time I wear this is when welding 904L fluxcore because the fumes are so harsh on your lungs to the point where it hurts really bad if you inhale just a little bit. I'll do 317L all day with just a fan pointed at me though.
Old Nov 27, 2011 | 06:39 AM
k24em2's Avatar
http://store.cyberweld.com/speedfresair.html
Old Nov 27, 2011 | 10:50 AM
Krator's Avatar
Ok they have an air extractor that is on the other side of the pieces I weld. It does a good job but I am worried about the gas from the torch going up the vent too. In effect ruining the welds. does a small draft bother it that bad?
Old Nov 27, 2011 | 11:16 AM
k24em2's Avatar
not usually
Old Nov 27, 2011 | 02:24 PM
Krator's Avatar
Oh ok I will use it then I won't need to bother with a breathing mask then. The blower sucks enough air that you feel a light breeze from behind you so it will work good.
Old Nov 27, 2011 | 05:33 PM
intense4thgen's Avatar
I run a little fan on my desk blowing air and fumes away from me. I also use as a back up the same 3m mask madmax posted although im sure my filters are a 2097?
Old Nov 27, 2011 | 06:04 PM
Krator's Avatar
Oh ok. I will see about that then. Every precaution I can. My COusin is a welder out near Calgary Alberta. He has a scare cause he might have lung cancer after welding for a number of years. He used a mask but I don't know what kind of welding he has done. Might as well be as safe as possible. No use asking for trouble.
RJ#9
Welding / Fabrication
Jan 19, 2009 06:18 PM
640K Crew
Jan 28, 2006 08:43 PM
.water
May 20, 2005 11:47 PM
Flamenco-T
May 4, 2003 07:02 AM
2K_TEG
Nov 5, 2001 09:27 PM
