FS: Type-R 4x100 11" upgrade w/ drilled/slotted discs
Integra Type-R front brakes upgrade for Civic EXs and Integras - $325
This is a set of the rare 4x100 front brakes for a Civic and Integra. This is a pair of ITR front calipers with the 23T brackets machined (milled) to fit the 4x100 knuckles. This also comes with a new pair of Prelude VTEC rotors, drilled and slotted.
This brake upgrade is a behemoth of an upgrade over stock, using the big *** Type-R calipers with their 57mm pistons. The brackets were precision milled to fit. The rotors were redrilled with a milling machine to 4x100. This bolts onto any 90-01 Integra, and any 88-05 Civic EX, 99-00 Civic Si. This can fit any other 88-00 Civic if you get Integra or Civic EX knuckles, as their knuckles are different with regard to the caliper mounting point.
You will definatly want a 15/16" or 1" master cylinder if you have a Civic.
Pads are ceramic, the rotors I'm not positive, but the slots are beveled and the holes are tapered, and the rotors are cross hatched on both sides, so they are great quality, on par with Honda given this looks like a replica, not come cheapo disc, as this was balanced first.
hondapwr
Sep 13, 2006 03:36 AM
