ek gsr turbo over heating (new thermostat)
Old Nov 25, 2011 | 03:13 PM
ja20_eg's Avatar
Default ek gsr turbo over heating (new thermostat)
i just replace a new thermostat in my car and my car now is over heating..my old one that was on the car was bad..that my temperture was alway very low!!!so i replace it with the new one.....my fan still kick in to..but still over heating..so let me get some advice from you guys...
Old Nov 25, 2011 | 03:14 PM
grumblemarc's Avatar
The Grumpiest
Default Re: ek gsr turbo over heating (new thermostat)
Blocked airflow? Aftermarket/stock rad?
Old Nov 25, 2011 | 04:27 PM
ja20_eg's Avatar
block airflow??? and yea i have a aftermarket rad...
Old Nov 25, 2011 | 04:30 PM
DPancoast's Avatar
Full size? Half rad?
Did you burb and fill the system properly?
Are both of your hoses warm at operating temp? One or the other?
Old Nov 25, 2011 | 04:32 PM
The Grumpiest
Yes. Is anything blocking the airflow?
Old Nov 25, 2011 | 04:34 PM
slowturbocx's Avatar
Are there any bubbles coming from the rad.?
Old Nov 25, 2011 | 04:35 PM
ja20_eg's Avatar
rad half size..and hole on top very hot and holes at the bottom is cold...
Old Nov 25, 2011 | 04:36 PM
The Grumpiest
Aftermarket fan? Shroud?
Old Nov 25, 2011 | 04:37 PM
DPancoast's Avatar
Could mean your new thermostat isn't opening.
What kind is it? Oem? Parts store replacement?
Old Nov 25, 2011 | 04:39 PM
ja20_eg's Avatar
yea theres bubble coming from to top rad cap..when i fill the rad when i got done putting the new thermostat in...
Old Nov 25, 2011 | 05:02 PM
ja20_eg's Avatar
yeah, i think it is cause my buddy and them said for me to take it back and get a new one (autozone)
Old Nov 25, 2011 | 08:17 PM
bradley's Avatar
There's your problem. I've used two autozone t-stats in my EF before and they both did this to me. Go get you a Honda t-stat.
Old Nov 25, 2011 | 08:28 PM
Linked's Avatar
did you install it backwards?
the big end of the thermostat should face the engine and the small end should face the rad hose
if you installed it backwards, the wax pellet in the stat will read the colder coolant outside the engine and not the boiling coolant inside the engine and will never open up to let coolant flow
Old Nov 25, 2011 | 08:41 PM
ja20_eg's Avatar
i install it right...i look at the one that was on it b4 i took it out to make sure it right..
Old Nov 25, 2011 | 08:42 PM
ja20_eg's Avatar
you mean the actual one from honda.....
Old Nov 27, 2011 | 08:53 PM
ja20_eg's Avatar
ok i check everthinng but now when im driving around town it seam to be at normal temp..but when im on hwy it gose on high temp...and my s300 pop up code overheating...
JENNY_EG6
Nov 30, 2012 06:40 PM
Boost16
Jul 29, 2011 02:21 PM
mortificationrock
14
Mar 23, 2009 12:04 PM
95stangkillah
Aug 9, 2004 09:21 AM
ek9si
Jun 18, 2003 04:42 AM
