how much would a b16 crx hf weigh, and other questions?
Old Oct 7, 2002 | 10:41 AM
soontohavecrx's Avatar
Default how much would a b16 crx hf weigh, and other questions?
does anyone sell performance axles for the swap?
what should it run both stock and with i/h/e skun2 cams, IM, TB and p/p head?
what header and exhaust would i be able to use?
Old Oct 7, 2002 | 10:51 AM
EP3_05's Avatar
Default Re: how much would a b16 crx hf weigh, and other questions? (soontohavecrx)
Driveshaftshop and http://www.raxles.com make performance axles for b series swaps. Kind of hard to estimate 1/4 mile times since every setup is different as well as driver skill and track conditions. As for a header any b series will work but some do require modification. Use an exhaust system that is designed for your car.
Old Oct 7, 2002 | 10:57 AM
Default thanks
how much do you think it would weigh would ~2100lbs. be logical? is it possible to get almost 200 flywheel hp out of a n/a b16?
Old Oct 7, 2002 | 11:08 AM
EP3_05's Avatar
Default Re: thanks (soontohavecrx)
A gutted hf can weigh under 2000 lbs easily. People have gotten 200 n/a whp out of b16a motors. So 200 flywheel is not out of the question.
classic86crx
Dec 26, 2012 10:16 AM
skiracer8148
Apr 12, 2007 07:27 AM
Metal Typhoon
Feb 21, 2007 02:09 PM
UnspokenTruth
May 10, 2004 07:42 AM
50shotRex
Feb 16, 2003 05:07 PM
