Just swapped ECUs and car runs like crap
Old Nov 25, 2011 | 02:43 PM
Dee6teen's Avatar
Default Just swapped ECUs and car runs like crap
the EK I bought had a Z6 swapped in it that was running off of an LS ECU. Not sure exactly why the hell they did this, but I bought a p28 and a jumper harness and swapped the ECUs. Now the car feels like it's running out of gas when I'm under 3k...above 3k fine. Sometimes for a brief period it runs perfect, then back to feeling like I'm out of gas. Once I hit 3k she picks right up and wants to go. Not sure what is causing this, has anyone else had this problem? Any fixes??? I'm guessing I need a new map sensor but I'm not an expert on Hondas yet so I would appreciate any help!
Old Nov 25, 2011 | 02:53 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Just swapped ECUs and car runs like crap
Why did you swap it? Some back story please.
Was the ECU you removed chipped?
Old Nov 25, 2011 | 03:00 PM
Dee6teen's Avatar
Swapped the ECUs because the car was idle surging from 1k-2k over and over and over and just didn't feel right and had that weird idle. Checked the ECU and it was a P75 i believe, off of an LS 1.8 non vtec. Well my motor is a Z6 with a Y8 head on it and is vtec. Swapped the ECUs because some people on here told me they couldn't believe the car was even running and I needed to get it on a P28 asap. I do not believe the ECU from the LS was chipped.
Old Nov 25, 2011 | 03:04 PM
The Grumpiest
Any CELs? Check timing? Swap done correctly? Last tuneup?
If the P75 is chipped you might want to check.
Old Nov 25, 2011 | 03:07 PM
Dee6teen's Avatar
Swap was done correctly yes, the car ran fine besides the idle issue on the P75. It is throwing code yes but I don't have vtec hooked up ATM and don't have a way to check which codes it's throwing. last tune up was about 3k miles ago.
Old Nov 25, 2011 | 03:13 PM
The Grumpiest
Paperclip in the jumper harness will pull the codes.
ozh_hawaiian
Oct 14, 2012 01:20 PM
97dxred
Apr 7, 2009 12:19 AM
DOHClessEF-9
Sep 16, 2008 05:57 AM
ecovillain
12
Jul 26, 2005 01:38 AM
ecovillain
Jul 21, 2005 11:23 PM
