neptune rtp, switching to stock p72 maps?
Old Nov 25, 2011 | 01:37 PM
Luke G.'s Avatar
Default neptune rtp, switching to stock p72 maps?
i have a tuned map on my rtp for my boosted gsr, i want to run the rtp on my stock gsr but i do not know how to get the stock maps? Do i just use the basemap creator and load in the p72 maps that way?
Old Nov 25, 2011 | 01:49 PM
SR20S13's Avatar
Default Re: neptune rtp, switching to stock p72 maps?
ummm watch the HRtuning videos on how to set it up and that will help you, its pretty easy if you had just searched
Old Nov 25, 2011 | 01:51 PM
Luke G.'s Avatar
ive watched those videos, im having an issue with throttle response for some reason
Old Nov 25, 2011 | 02:31 PM
HRTuning's Avatar
Yes, you can use the stock P72 maps in the basemap creator. Make sure you save a copy of your old tune or switch to a different tune in the software so you don't overwrite your old one. You need to upload base code after the map is created. If you didn't try to adjust anything it should run like stock. Please use the NepTune forums for any other questions you may have.
Old Nov 26, 2011 | 05:04 AM
Luke G.'s Avatar
I got it to work this time, im not sure why it wasnt running correctly the last time i tried doing it. Thanks for the input.
Old Nov 26, 2011 | 06:28 AM
HRTuning's Avatar
No problem.
hymn
Engine Management and Tuning
Aug 16, 2014 03:09 AM
Pssst!
Apr 6, 2011 09:36 PM
mario_pic
Jan 25, 2008 08:37 PM
wytechoppin
Jul 27, 2006 06:22 AM
Rus1an
14
Nov 13, 2005 09:44 AM
