JDM GSR swap into LS wiring question
Old Nov 25, 2011 | 10:20 AM
Teggerson's Avatar
Default JDM GSR swap into LS wiring question
So I'm planning to swap a JDM b18c1 into my USDM 94 LS which currently is running a obd2 LS motor.
Will the sensors and harness be the same and work? and will the usdm ecu work fine?
Will I have to make some wiring modifications other than wiring vtec?
Old Nov 25, 2011 | 12:08 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: JDM GSR swap into LS wiring question
You should be fine wiring wise as long s the B18C1 is OBD1. For the LS did you use and OBD1 distributor, injectors and alternator? You'll have to wire VTEC, knock sensor and the IAB's. The USDM ECU will work fine.
LOVEthatDC2
Jul 26, 2009 11:49 AM
dc4teggiehatch
Jul 22, 2007 10:48 PM
blackdelslo
Dec 1, 2005 12:18 PM
3minburnout
Sep 16, 2003 08:30 PM
