FS:98 Honda Civic D15 Engine and Trans and exhaust manifold CHEAP
Hey guys I have a Civic D15 swap i took out of my friends car. He upgraded to a B series.
This swap will bolt in to your car and work but it does need repairs. First it has a burned valve in cyl 2. this was caused by the egr valve being broken... so it needs a new egr and valve job on cyl 2 and it will be good to go.
Everything in the pictures is included.
100 takes it
exhaust manifold has tiny tiny hairline crack.
100 takes it
maybe it is a d16 ill double check im more of an integra guy which is a big reason i really dont want this engine swap
150$ for it cause thats about what i will get for it if i recycle it you can part this out or make repairs and use it in ur car... or you literally could just use it as is... it runs it just has a burned valve so if u just fix that and replace the egr the engine is good to go
I want to sell it TODAY
