91 crx hf steering problems
Old Nov 24, 2011 | 02:16 PM
ChokolAwt's Avatar
Default 91 crx hf steering problems
at highway speeds and under hard braking, the car wanders left or right. pretty scary to drive haha. ball joints, inner tie rods and outer tie rods have all been replaced as well as an alignment a few thousand miles ago.
i am unsure how long this "wandering" issue has gone on for since i bought the car 2 days ago.
Old Nov 24, 2011 | 02:27 PM
91efbluehatch's Avatar
Default Re: 91 crx hf steering problems
sounds like some excessive play in the rack and pinion.
have you also checked your brakes, calipers, and rotors?
Old Nov 24, 2011 | 05:16 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
So you put a "few thousand miles" on your vehicle in the past 2 days? How do you know they weren't lying to you? Your rack and pinion may need to be adjusted. It's easy to do, there is a write-up for this.
Old Nov 24, 2011 | 05:47 PM
ChokolAwt's Avatar
so you guys are saying play in the steering rack? i'll check the u-joint this weekend.
to clarify, the alignment/tie rods/ball joints were all done by previous owner. i have the receipt from the shop.
Old Nov 24, 2011 | 05:50 PM
ehhh...personally i would have it all rechecked. its like $74 for a complete front end service here in Mississippi.
but i'd be willing to bet its something in the rack..
Old Nov 24, 2011 | 06:01 PM
DO IT ON ALL FOURS
The "u-joint" probably isn't the problem, although it wouldn't hurt to check it out, if it is the rack - the manual ones have an adjustment. Obviously you are unsure so just take it to a shop. Around here I believe they only charge $10-15 for a front end check.
Old Nov 26, 2011 | 03:54 PM
ChokolAwt's Avatar
i checked the faq on this site and didn't see anything about adjusting a manual steering rack. is there a good article somewhere i could follow?
Old Nov 28, 2011 | 04:29 PM
jasons's Avatar
I'd look into the front brakes.
Good luck,
~Jason
Old Nov 28, 2011 | 05:15 PM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Also see if you can jack up the front end and do some wiggle testin'
ra64
Sep 15, 2014 06:48 PM
silentdarkness1317
Classic Hondas
Mar 6, 2011 08:17 PM
furiousbob
Mar 13, 2009 02:26 AM
B2FiNiTY
14
Dec 19, 2003 08:34 AM
Martaigne
Jun 14, 2002 07:07 AM
