FRONT Wheel Hub and Bearing
Old Nov 24, 2011 | 02:11 PM
delinquent's Avatar
Default FRONT Wheel Hub and Bearing
Hello all,
I have a 1991 Honda CRX Si with 92-93 Integra GS-R Swap.
I am looking for a FRONT Wheel Hub and Bearing for a 92-93 GS-R (No ABS), because it turns out they swapped everything from the GS-R. I not knowingly bought a CRX Si Front Wheel Hub and Bearing and it is too small.
I cannot find this anywhere on Advance Auto, Autozone, or eBay. Can someone point me in the right direction? A good OEM replacement that doesn't cost an arm and a leg would be nice.
Thanks!
Old Nov 24, 2011 | 03:29 PM
KINGVEM^^ED6's Avatar
Default Re: FRONT Wheel Hub and Bearing
May have to go oem call acura
Old Nov 24, 2011 | 04:21 PM
delinquent's Avatar
Rear hub assemblies are available, but nothing for the front. This sucks! I find it hard to believe that this part is not more readily available... Calling the dealer sounds expensive.
Old Nov 24, 2011 | 04:45 PM
Call acura and get the part number then call honda and cross reference pn's maybe something will work and hondas usually cheaper gl bro
Old Nov 24, 2011 | 05:08 PM
TheRealTegger's Avatar
Originally Posted by delinquent
Hello all,
Thanks!
All 2nd-gen Integras, whether '90, '91, '92, '93, RS, LS, GS, GS-with-leather, GS-R, 3-door, 4-door, ALB, non-ALB, whatever... use the exact same knuckle, hub, and wheel-bearing.
This may help you locate an aftermarket part.
You let the bearing get too noisy and it spun on the hub, right?
Old Nov 24, 2011 | 06:48 PM
delinquent's Avatar
^^thanks but the only front hub and bearing I can find is for 94+ integra. boggles my mind how something like this isn't available.
I never noticed the front making noise since I owned it, but realized the bearing was bad while we were in the process of changing the clutch.
Old Nov 25, 2011 | 04:46 AM
delinquent's Avatar
here is the front wheel bearing for the 90-93:
http://www.ebay.com/itm/200494798600...ht_1223wt_1164
If I could only find the hub now..I messaged the seller asking him if they happened to have one.
Old Nov 25, 2011 | 05:02 AM
I'm curious why you need a hub. Those generally last forever unless the bearing seizes and spins in it.
Old Nov 25, 2011 | 06:40 PM
freaks_smk91's Avatar
He wants the assembly so he dosent have to get it pressed in..try rockauto.com they usually always have wat I need n their prices r pretty good
Old Nov 25, 2011 | 10:32 PM
mark@silbernage's Avatar
Les Schwab did one for me - they have a press for doing it.. took 'em about 1/2 hour and he charged $40.
Friend of mine had a press at his father-in-laws, so having watched the first one we did the second ourselves.
Long as you have the press, not bad.
Getting the inner bearing race off the hub was interesting. We both used a 3" grinder to cut it diagonally (not all the way thru) so that we could then take a chisel and hammer to tap/spin it off. The cut loosened it so it would move.
Mark
Old Nov 26, 2011 | 05:02 AM
You're thinking of the REAR hub/bearing combo, which comes as one-piece. The front bearing comes all by itself and must be pressed onto the hub and into your steering knuckle.
I'm thinking the hub is hard to find outside of the dealer because nobody ever replaces them.
Old Nov 26, 2011 | 04:28 PM
No I'm thinking about the front..when I replaced my bearings I bought some that came with the hub..u can find them u just have to come outta pocket a little more..but ur right either way u have to press it back into the knuckle
Old Nov 27, 2011 | 09:40 PM
SlidewaysSnake's Avatar
any shop that has a press should do it for $40 or less if you have the assembly out of car
03K20A3Si
Classic Hondas
Aug 12, 2011 02:31 PM
hybrid1990crx
Nov 12, 2010 11:02 AM
Driven
May 5, 2005 04:57 PM
WRTEG
Apr 28, 2005 03:04 PM
REVolution
Apr 3, 2002 06:41 AM
