power steering leak 1992 civic
Old Nov 24, 2011 | 11:52 AM
swizz977's Avatar
Default power steering leak 1992 civic
its leaking from somewhere by the resovour i think since theres fluid by there
Old Nov 24, 2011 | 01:07 PM
grumblemarc's Avatar
The Grumpiest
Default Re: power steering leak 1992 civic
And?
Old Nov 24, 2011 | 01:22 PM
98civdx's Avatar
Master Detailer
What do you want us to tell you?
You need to get in there and start looking. There is no other way.
Old Nov 24, 2011 | 05:17 PM
Former User's Avatar
Maybe a cracked hose or a loose clamp on the pump.
Old Nov 24, 2011 | 05:41 PM
sickrex123's Avatar
^^^^ check that ... and also check to see if for some reason you have a crack in the reservoir, not something that would normally happen, but you never know
Old Nov 24, 2011 | 06:09 PM
swizz977's Avatar
idk it makes a wierd noise on startup moves a lil
Old Nov 24, 2011 | 06:27 PM
Blacknight117's Avatar
With little info to go on, we can`t really help you. But check for a cracked resevoir or maybe a busted line. If the pump is making a weird noise, make sure you put in GENUINE HONDA POWER STEERING FLUID if the fluid is low. Also, check the rack too...
Old Nov 24, 2011 | 07:25 PM
Linked's Avatar
it doesn't have to be genuine honda fluid, it just has to be power steering fluid specifically for hondas
Old Nov 25, 2011 | 04:35 AM
The Grumpiest
Are you just standing there looking at it scratching your head or are you trying to figure out where the leak is coming from, if it is even leaking?
If your threads go true to form you'll drop additional crucial info that you should have put in the first post.
So far everything that has gone wrong with your car has been because of something you were doing. SO what were you doing to the car that caused this "leak"?
Old Nov 26, 2011 | 12:39 PM
swizz977's Avatar
check the steering rack?
Old Nov 26, 2011 | 12:45 PM
The Grumpiest
Did you find out where the leak is coming from?
curtie94
Feb 24, 2012 12:38 PM
questseek
Mar 6, 2010 09:32 PM
h23siaws
Jan 23, 2009 05:58 AM
Silvteg95
Aug 1, 2005 06:59 PM
'00Accordster
Sep 25, 2004 08:52 AM
