Sluggish D16y8 what could be the problem
Old Nov 23, 2011 | 06:26 PM
Mobeious's Avatar
Default Sluggish D16y8 what could be the problem
ok when i first start the car its fine throttle response is good and gets up and goes but once the engine heats up to normal temp the response is gone
coming from a complete stop i really have to give it some revs to get it going without it jerking and once going after 2-3k rpms its like it grabs a gear or somthing and takes off then same situation in 2nd gear ... almost like something is holding the motor back untill 2-3k rpms
i have adjusting timing and it is spot on ... has new plugs ... fuel filter and oil and i just replaced the upstream 02 sensor... the downstream is throwing a code but i was told that just measures cat efficiency and does not hinder teh engine and i only run 93oct in it
anyone know what i should be looking for ?
Old Nov 23, 2011 | 06:30 PM
furious94ls's Avatar
Default Re: Sluggish D16y8 what could be the problem
Start with the basics. Wires, cap, rotor? Is that the only code? I'd replace it anyway. Check for vaccum leaks as well.
Old Nov 23, 2011 | 07:02 PM
apexi_rsx's Avatar
your pissing away your damn money throwing 93 octane in a motor that does not require it because its low compression and does not make enough power to need 93 octane. you wont get any better gas mileage using it either. replace the cap/rotor and possibly the ignitor and see how that helps.
Old Nov 23, 2011 | 07:14 PM
10psiLsEf2's Avatar
swap the o2 sensor.
and why in the funk are u running 93
Old Nov 23, 2011 | 07:41 PM
motegicivic's Avatar
All the d16y8's are like that, feels like there is a lag from 2k to 3.5k.
Curious do you have an aftermarket exhaust?
Old Nov 23, 2011 | 08:11 PM
98civdx's Avatar
Master Detailer
OEM cap/rotor/wires? NGK plugs, that are gapped correctly?
Replace the O2, and stop puting 93 in it. your wasting your money. These cars don't need anything other then 87.
Old Nov 24, 2011 | 03:35 AM
Mobeious's Avatar
i think i used champion spark plugs and yes i gaped them
well when i fill up there is only a 2 dollar difference between using 87 and 93
Old Nov 24, 2011 | 04:12 AM
NOFX's Avatar
H-T White Ops
My Y8 doesn't have a lag.
What do you think is the benefit of using premium gas instead of regular?
Old Nov 24, 2011 | 04:54 AM
grumblemarc's Avatar
The Grumpiest
If regular is good, premium must be better. Because it's premium!
Run NGK plugs and the grade of gas recommended by Honda.
Old Nov 24, 2011 | 08:16 AM
Well I have an auto, my car since new was weak from 2k to 3.5k or so, these engines are designed to run in the higher rpms.
Old Nov 24, 2011 | 08:52 AM
98civdx's Avatar
Master Detailer
I have an auto Y7, no lag.
Old Nov 24, 2011 | 08:55 AM
Wrona's Avatar
run gas recommended by honda you are not running high compression
Next get everything OEM not crappy auto parts store stuff its more expensive but it lasts longer preforms better
you can find a full tune up kit n ebay for 60 bucks including NGK Wires, Plugs, Rotor, Cap, Fuel Filter
I would also run a Can of BG44K before replacing the filter thats what i usually do before every filter change i add bg44k and after the full tank is gone i replace the filter
Ottombille
Jan 29, 2016 04:39 PM
Recklesszz
Jan 30, 2013 08:30 PM
Navy_Kyle
Oct 24, 2012 05:43 AM
skyclimber
Jan 24, 2012 10:48 AM
JDM215
Nov 18, 2010 11:39 AM
