Wheel security
Old Nov 23, 2011 | 02:00 PM
tineysmiles's Avatar
Default Wheel security
So I recently just bought some wheels and i'm pretty iffy about not having enough security for my car especially with all the "stolen car, wheels, etc" I've been hearing and I don't even have a garage. I've been considering a ton of options like a set of $350 lock lug nuts but it's too pricey. Then there's the whole different lug nut thing and that only just slows them down but doesn't prevent it. Is there any other options out there?
Old Nov 23, 2011 | 03:00 PM
toyomatt84's Avatar
Sanji
Default Re: Wheel security
Wheel boots/clamps typically can deter thieves.
Old Nov 25, 2011 | 12:34 AM
Safety_Driver's Avatar
Icon2 Re: Wheel security
I was about to ask the same.
I have after market lock lug nuts, but they are for my aftermarket wheels.
I'm looking for some OEM Honda lock lug nuts, with the acorn Honda profile for my HX rims.
Old Nov 25, 2011 | 08:28 AM
toyomatt84's Avatar
Sanji
You should be able to get a set of keyed Honda lug nuts from your local Honda dealership.
Old Nov 25, 2011 | 08:37 AM
kaiba's Avatar
Weld your rims to your brake rotor/hub.
Old Nov 25, 2011 | 10:22 AM
Libertariat's Avatar
Ek Forever y0!
http://www.jhpusa.com/store/pc/viewP...idcategory=172
Locking Lug nuts wouldn't be a bad idea, here are some really cool ones.
I'll probably be getting some next year to keep my Volks safer.
Originally Posted by Kics Racing
The unique feature (patent pending) of this seven-sided, heptagonal lug nut is that each lug consist of 2 pieces, where the top of the lugs spin freely from the tapered centering ring. This ensures a much tighter and precise hold than traditional lug nuts. It also minimizes the chances of scratching your wheels. Made of lightweight composite materials, these open ended lugs fit on both standard studs as well as extended studs. The entire set weighs just under 2 lbs! Highly recommended for both street and track enthusiasts.
Please specify size.
Edit: Much cheaper on Ebay
Old Nov 25, 2011 | 01:39 PM
dem0nk1d's Avatar
locking lug nuts are a dime a dozen, not all are created equal. Fact is many stock honda locking lug nuts share the same key, or actually may only have a total of 5 different ones in total. Another thing is if you ever lose most wheel keys, you can always use a bigger 12point socket and hammer the damn thing over it to remove the lock. So the whole idea about wheel locks are a just use as a deterrent.
http://www.youtube.com/watch?v=T8Uc2SlkSPM
Old Nov 25, 2011 | 01:40 PM
dem0nk1d's Avatar
Now on another note, i'm using the PIAA locks and there is no possible way i can remove the damn lock if i wanted to without the lock. The way my rim setup is, that there is no clearance, to do the method above.
Old Nov 28, 2011 | 12:18 AM
DawgC2's Avatar
excellent solution! problem solved! it actually promotes higher road safety and parts unity as you need to get new hubs and rotors for every tire change! lol
Old Nov 28, 2011 | 02:02 PM
Cs45F's Avatar
They can get the lock off if they really want to but for the most part the quick wheel thieves aren't gonna have different sized sockets and a hammer with them so most likely it will slow them down.
Old Nov 29, 2011 | 12:19 PM
TunerN00b's Avatar
Originally Posted by Cs45F
They can get the lock off if they really want to but for the most part the quick wheel thieves aren't gonna have different sized sockets and a hammer with them so most likely they'll take the whole car and deal with it later.
FTFY.
Old Dec 5, 2011 | 02:36 PM
thanks guys! but is there such thing as a set of lug nuts with their own specific key? meaning that no one else can get the key unless they have the serial number of that set. sorry if i'm explaining it confusing! lol.
Old Dec 5, 2011 | 02:51 PM
toyomatt84's Avatar
Sanji
There are plenty, to be honest. Just Google "locking lug nuts", and you'll find quite a few. There are a couple companies out there that produce magnetic locking lug nuts, as well, which are a little more elaborate.
Old Dec 5, 2011 | 02:54 PM
TunerN00b's Avatar
You want a unique key for the set.
To my knowledge, this doesn't exist.
You can always have your own cut. And then you'll really wonder why you wasted the money when the thieves just bash a 12 point socket over them and take the wheels off anyway. Locks just slow thieves down, and pretty much all of them provide about the same level of protection. Just buy a good name brand set and call it "good enough".
keep it 100
Jun 11, 2011 01:05 PM
cbstudd77
Nov 28, 2006 09:45 PM
nsxtasy
Feb 6, 2006 03:47 PM
VTECTIME
Oct 16, 2002 03:48 PM
B2FiNiTY
Oct 16, 2001 08:08 PM
