CV axle milling away at shock lower fork
Old Nov 23, 2011 | 09:32 AM
91efbluehatch's Avatar
Default CV axle milling away at shock lower fork
so i pulled my driver side wheel off to gain access to the lower part of my motor to the trans bracket....and i see that my CV axles has milled away at the shock fork????
IDK what would cause this.
i am using DA integra INT shaft, and axles as well.
4dr sedan knuckles
but i am still utilizing my stock lower fork assembly.
its concerning me bcuz i dont want it to snap in half and cause me to wreck.
any insight as to what would cause this??
Old Nov 23, 2011 | 10:25 AM
Default Re: CV axle milling away at shock lower fork
mods please close. figured it out.
Old Nov 23, 2011 | 10:49 AM
crvtectim's Avatar
What the problem was?
Old Nov 23, 2011 | 11:45 AM
nickrps's Avatar
I'm thinking the shock fork was on backwards?
Old Nov 23, 2011 | 07:03 PM
two bolts in the rear trans bracket had backed out causing the motor to shift back and push the CV axles into the fork
^^HAHAHAHAHAHAHA^^ UMMMMMM....NO
Old Nov 23, 2011 | 08:25 PM
crvtectim's Avatar
Cool, glad you spotted that before threads started ripping out of the case.
Old Nov 23, 2011 | 08:29 PM
im glad i spotted it as well.
i was driving in the rain, and accidently spun in second and i spun in third. idk what i hit, but it just spun like crazy and i had no traction..
guess sand and lots of rain water dont mix on roads by the beach =/
but i noticed my motor klunking whenever i would shift regularly, so i thought this isnt too good.
pulled over at an autoparts and i could push the back end of the motor up and down so i knew some bolts were missed placed.
so i babied it on the way home, granny shifting. i know my clutch could have killed me, but it will be all right.
took a total of 15mins to put two new bolts in, and torque em down
GraphiteMW
Mar 5, 2007 08:53 PM
keepitngga1
Dec 21, 2006 05:00 PM
baked_beanz
Jun 1, 2005 04:02 PM
type Gendy
Jan 19, 2003 06:18 PM
echo999
Jul 10, 2002 01:52 PM
