Degreeing cam's?
Old Nov 23, 2011 | 09:29 AM
yungkhmer's Avatar
Default Degreeing cam's?
I have crower 403's and crower says to degree the cams in. I was wondering since my block is stock for now would i benefit from this? Do i get a noticeable power gain?
crower 403's
crower valve train
stock valves
skank2 cam gears
thanks for any imput.
Old Nov 24, 2011 | 03:08 AM
fcluddington's Avatar
Default Re: Degreeing cam's?
when you degree the cams in you will find out in degrees how much they can be adjusted. If you dont degree them and the piston hits a valve the first thing everyone will ask is.. did you degree the cams in? I think once you get into it you will find it's not that intimidating or if you have a good local engine builder have them do it maybe they let u watch.
Old Nov 24, 2011 | 05:41 PM
fcm's Avatar
fcm
Old Fart
Do you have adjustable cam gears? 94
Old Nov 24, 2011 | 06:56 PM
JustOneOrTwoPosts's Avatar
He stated he has Skank2 cam gears
Old Nov 24, 2011 | 07:25 PM
mechanix619's Avatar
crower 403's
crower valve train
stock valves
skank2 cam gears
OP, are you running stock valves with Crower springs and retainers? Is the spring rate appropriate for the cams?
Yes, if Crower says the cams need to be degreed then it is mandatory in order to have proper piston-to-valve clearance. Also, you do not need to install cam gears in order to install the camshafts. Cam gears and degreeing cams for p-t-v clearance are two separate issues. With that said, you will not get as much power out of the camshafts without the cam gears but they are not necessary for installation.
To your primary question, if your engine is mostly stock then you probably will not see a huge gain by adding the camshafts, you could potentially make the engine run rough. Are the camshafts aggressive or slightly better than stock?
Old Nov 25, 2011 | 05:45 AM
fcm's Avatar
fcm
Old Fart
DOH!!! missed that.
It is important to "degree" the cams, Skunk2 has a good writeup... http://www.skunk2.com/camshaft_tech.php 94
Old Nov 30, 2011 | 04:31 PM
yungkhmer's Avatar
YES stock valves with crower dual valve springs and tit. crower retainers. I guess i gotta find somebody to degree them since crower does recommend it. thanks.
sitinthehall
Jul 24, 2005 06:05 PM
velocitytrends
Apr 29, 2004 04:01 PM
DefiantGSR
Apr 14, 2004 12:44 PM
PainfulTeg
Sep 23, 2002 12:08 AM
