NEW HERE AND NEED SOME ADVICE
http://www.ebay.com/itm/HONDA-CIVIC-...item4cfb6f8080
HEY GUYS i recently got a new honda and im going to be adding a turbo to it in the spring and i bought a turbo kit off ebay as i put the link in up above ^^^
So i havea few questions ehre i would like to ask so i don't sound like a new noob
1. What should i be looking for when it comes to adding a turbo kit ?\
2. i was told by andys auto sport and a few guys if im going to be adding 8 pob(pounds of boost).. in my car i can run off of stock injectors and fuel pump ?.
3. i have a 1994 honda civic sedan it has a 1.6 v-tec 5 speed in it hydrolic clutch so if that helps i wantt o find a spec sheet for this so i can do this the right way im going to be speding the winter researching and doing other things of that then spring time im going to finish building the car.
4. can someone help me figure everything out the right way if i run into some issues and cant figure it out my self ?..
if anyone can help or piont me in the right direction then i would really thank you for that ...
also here is my number 1-469-274-0919.
you are dumb for buying that turbo kit plain and simple you did no reasherch what so ever and you think its just a bolt on affair
like you were all knowing and knowledgable when you started lol
iv seen the bolt on kits done correctly but theirs always gonna be misc parts you will need....as long as the turbo doesn't just dump oil you should be fine just keep the boost and expectations low
and you will still need some sort of tuning
You could keep the intercooler, charge pipes, and maybe add some better welds to the manifold. Then work on getting a good turbo, BOV, and WG. but should really upgrade inj. and pump. plus a tune obviously. just trying to help.
but yes, next time do more research.
Hi kc12305,
That's is great you got "nice" turbo kit for only 600$... Normally this is price of nice intercooler...
Now you need to start working on your engine if you are really "going to be adding 8 pob(pounds of boost)..." Stock injectors and fuel pump you most likely will blow your D16 no time...
Even if you will try run on stock internals I would still get at list 345 cc injectors, walbro 190 fuel pump, ARP bolts and AEM fpr...
Also there is one more problem with stock D16 engine, your Compression at 9.4:1 which is still high compression for turbocharger...
Do the research and get your car ready for that T3/T4...
Good luck!
Good luck!
Brand name parts. Cheap eBay turbos are garbage. You need a good turbo (Garret, Precision, etc). You need a high quality wastegate and BoV (Tial, Greddy, etc)
Sounds like you were misinformed. You need a larger fuel pump (Walbro 255 works great) and larger injectors. You also need a TUNE. That cannot be overstated. Also, unless you know the exact turbo you are talking about, 8 psi means nothing. What is your horsepower goal?
What trim level is your car? What specific engine? It will be stamped on the engine block and be parsed similar to D16Z6, B16A2, etc.
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Read those links, then use the advanced search for any questions you may have. If you can't find the information you're looking for, then ask a tech question in the forums.
Also, you may not want to post your phone number...you can't trust people on the internet with info like that
Keep the manifold, intercooler, piping, oil catch and trash everything else or sell it.
^^Please don't listen to this guy.^^
Hi kc12305,
Good luck!
Good luck!
Hi kc12305,
Good luck!
Good luck!
Hey guys i bought this AWESOME RICER Turbo that will blow in probably 2 days after i put it on because i wont tune my car because i don't even know what tuning is ill just slap a chip in my ECU because that's what everyone is telling me to do I have done no research BUT DON'T FLAME ME because i like to be spoon fed all my answers because i am on the internet but i am to lazy to go to google and actually do my own search because its much easier to come to HT and ask because i'm new...
I'm sorry OP but you did nothing to even find out basic stuff about forced Induction you just went on ebay typed in Turbo kit honda found the cheapest one and was like deal and bought it.. you threw away your money, my manifold cost me 700 dollars for my audi alone when i built it a lot of people think turbos are cheap because its a honda that's why they end up at the local junkyards here and allow me to collect parts for my projects
now you're going to be like
"Wrona quit hatin home dawg i haz a hella mad JDM Turbo kit that will run 10PSI because andys auto sport (overpriced ebay parts most ricers buy there) told me i can run 8psi" PSI doenst mean **** because one turbo on 8psi will make more horsepower than a smaller turbo
you needed a reality check next time dont expect to be spoon fed
well i didnt even do the above i was given the turbo kit from my grampa and i didn't want to bitch im not a creedy person all i wanted is to ask what i thought was right the only bad thing i did so far was ask this forum what i was curious about and this forum witch has nothing but rude and qucik to judge people on it some ppl are nice on here but from what i saw its has nothing but that
as of what i have read as of now.
Hey kc12305, you can ignore this post like jdmadam said but ill give you little guide on your D16 build if you still down for it...
In the fist place you need to build your engine, D16 not a best engine for putting money in but its probably cheapest one to build.
So first get low compression pistons, I found some on ebay for 135$ (http://www.ebay.com/itm/YCP-Vitara-P...item2a14d04085). Not JE but will save you 300$ at list...
Sense you will have to take rods off your crankshaft you need to get Main and Rod Bearings (Standard ) im guessing you wont be machining you crank so don't buy over sized ...
Not sure how much HP you D-series rods will hold but I would get something better then your stock ones, I'd go with Scat Connecting Rods 300$ (http://www.cimotorsports.net/motor-s...t65394187.html)
Next thing you will need is new head gasket, found one here also
http://www.cimotorsports.net/motor-s...civic-d16.html )
Bolt down you head on ARP head bolts with proper torque spec... DO NOT REUSE YOUR STOCK BOLTS!!! (About 100-170$ depending on where you buy those.)
Get new timing belt sense you will take your head off.
Injectors and fuel pump is really important for turbocharging your car, with small injectors you will lean your engine out. Get 440cc just to be safe, will cost you about 150$ of ebay... For the fuel pump go with Walbro 255LPR-90$(I know I said 190 before but sense you building your engine go with 255.)
Now to get that working get AEM's Honda/Acura Adjustable Fuel Pressure Regulator, about 150$ new... don't buy cheap crap "Made in China" those most likely to leak...
Also need Fuel Pressure Gauge-50$
I've noticed you got cheap 15$ boost controller, get rid of that... get something better... like Turbo XS Standard Boost Controller -75$ or something reliable...
Your ECU needs to be chipped so look on ebay, I would buy RICH-TUNED ecu...
One more thing I would buy, would be 2.5" exhaust if you dont have one already...
Last one: Dyno! abut 450$ depending on what your local shop will charge you.
So from what was said above... you looking at 1000$-1500$ in parts if you do all the labor your self.
This was based on D16Y8 engine so this is just to give you some idea... I didnt mentioned some things like honing your cylider walls or doing work on your head... Do the reserch on each step you take...
Every one welcome to put there buck fifty in!
http://www.cimotorsports.net/motor-s...civic-d16.html ) Bolt down you head on ARP head bolts with proper torque spec... DO NOT REUSE YOUR STOCK BOLTS!!! (About 100-170$ depending on where you buy those.)
You dont need a FPR...you should be running OEm pressure and adjusting youre injectors for more fuel...Adding more fuel pressure isnt the best method to increase fuel...If you need more fuel get bigger injectors. Mine as well get bigger then 440cc for future growth.
you will need alot more then just a chipped ECU on Ebay. ( although a chipped ecu is needed for chrome, ectune, ect) Get a standalone system, if Youre trying to cheap out on everything then dont turbo it. There are ways to save money but Cheap and simple can get Expensive and complicated really Fast especially with youre first build when youre still learning.
Also stick to OEM gaskets, headgaskets, manifolds ect.
