CRX GSR to LS swap
Old Nov 23, 2011 | 07:50 AM
screwdgie's Avatar
Default CRX GSR to LS swap
So I am looking at picking up a friend's CRX that has a GSR swap with a blown motor. Since I am kind of poor and I can get an LS motor cheaper than another GSR, would that be a direct swap? I believe it has a P72 ecu, that would need to be swapped also correct?
Old Nov 23, 2011 | 08:32 AM
csingham's Avatar
crazy mad murdock
Default Re: CRX GSR to LS swap
direct swap, minus the wiring, ecu, and such. Do you get the entire engine? if so what is "blown"
you can sell the head, throttle boddy, sensors, distributor and it probably will pay a third of a new LS
Old Nov 23, 2011 | 08:36 AM
4drEF's Avatar
Keyboard Humorist
If the head is good, it could be good times putting it on the LS, or trading it for a B16 head.
Wiring should be the same.
Just no vtec or IAB connection on the LS motor.
Run an OBD1 LS ECU.
Old Nov 23, 2011 | 08:47 AM
screwdgie's Avatar
Not exactly sure what is wrong with the motor, but I was told it wont even start and has super low compression on 2 cylinders. He said he took it to a shop for the swap a few yrs ago and the guy screwed him and the gsr motor that was put in smoked and burned oil from day 1 of the swap...
Old Nov 23, 2011 | 04:35 PM
zrickety's Avatar
Sounds like it just needs a rebuild. Should be cheaper than the LS but you need to look inside.
Old Nov 23, 2011 | 06:26 PM
EFlove66's Avatar
tear apart that gsr bottom end, throw some low compression pistons and an ls crank. then boost the **** out of it. now that's a car :p
Old Nov 24, 2011 | 01:07 PM
csingham's Avatar
crazy mad murdock
or just rebuild it and have a reliable engine that will last more than six months without the boost
Red-Rag-B18
Mar 5, 2010 01:24 PM
jikespingleton
Dec 2, 2006 04:18 PM
96LsBang
Mar 26, 2006 05:30 AM
vtecsiqt
Jan 20, 2002 10:10 PM
