no start
Old Nov 22, 2011 | 02:10 PM
powerfox66's Avatar
Default no start
I am trying to help a friend.. https://honda-tech.com/forums/honda-prelude-4/h23a1-h22a-swap-no-start-3000719/
powerfox66's Avatar
Default Re: no start
Originally Posted by powerfox66
just that no one has posted in other thread i figured to try here..ty
Old Nov 24, 2011 | 06:13 PM
fcm's Avatar
fcm
Old Fart
Connect a 12V test light to the pos.(+) and neg.(-) of the external coil crank the engine, if test light flashes the ICM, TDC, CYP and CKP must be good, so if spark is an issue it is the coil or after it.
You said injector pulse was weak/random, make sure both IPG1 and IPG2 at ECU/ECM have power when ign. switch is on and when cranking to start.
Do the same with all injectors, confirm there is 12V+ at each injector when ign. switch is on and when cranking to start.
I assume you have done the obvious...
Check valve timing.
Check ign. timing.
Compression test.
Checked valve lash.
If the above have not been done, do them, let me know what you find. 94
Old Nov 24, 2011 | 06:14 PM
dipsy's Avatar
Hookers and blow
did you try turkey?
wunfstgsr
Sep 7, 2017 09:01 AM
doktav
Jul 2, 2011 05:39 PM
spender1326
Mar 14, 2009 05:51 PM
skinny1
Nov 10, 2008 03:44 PM
erniecombs
Sep 26, 2007 06:21 AM
