Bseries Parts ITBS/CAMS/TRANNYS/HEADS/HEADERS/BLOCKS
I just want to start out by saying do not waste my time. The price i post for each item is firm. Im not here to scam or rip people off. Please calls only about items. 425 286 5100
Updated 3/6/12
Everything Must Go!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
B18c5 usdm type r tranny with less then 1k on it. I got it new from an acura dealer online amd put it in my b20vtec after about 800 miles i dropped a valve. its on my b16a2 in my car you can test the tranny out. 1100firm
Buddy Club Spec4 cams. Less then 500 miles on them with the two boxes they came with and cam spec card. 500
Skunk2 Tunner2 cams no idea on miles but in very good condition 350
Precision 440cc injectors less then 500 miles 175 with papeers
B16A head bare no valves clean head the number three camber got tapped my piston needs a resurface 180
I got two b16 heads for parts good rockers let me know what you need.
Bseries half shaft i have both kinds 30ea
Bseries vtec dizzy b16a2 with stock p30 wires 75
P28 socketed ecu 125
Type r head studs 50
Bseries alternator 45
Bseries vtec solenoid 55 got two of them
b series speed sensor 40
b16a2 starter 65
EF Bseries Tbracket 30
Ek Bseries Tbracket 30
eg bseries tbracket
Moroso catch can 100
ctr crank pulley 40
obdo b16a dizzy 65
fog light harness and switch for integra dc and eg 20 each
itr integra rear control arms 35\
iac valve 25
b20 oil pan 35
ek column cover 30
ecu p72-a05 obd2b 75
ecu p2n-a22 35
ecu pm6-a09 80
ecu p07-a01 80
ecu pt2-a12 50
d series lon side axle 25
Acura integra black Right door 2dr 100
Ek hb 99 red passanger door
jdm eg6 oem fenders with side markers back 100
integra ls axle back muffler 75
front 00 civic si control arms and sway bar set up 75
eg front core support cut with front frame rails 75.
bseries flywheel got 2 offers
Ek4 interior front seats and rear, door panels and arm rest 600 rears with head rest setup right know with eg rails and fit in eg hb
Please call me no texting for more info or pics. Do not waste my time if you have no money or you think my price is to high. 425 286 5100 and if you need anything for a bseries that i did not post just call me up and ask 100% i will have it.
Updated 3/6/12
b16a2 starter 65
eg bseries tbracket
ctr crank pulley 40
obdo b16a dizzy 65
iac valve 25
b20 oil pan 35
ek column cover 30
ecu p2n-a22 35
ecu pm6-a09 80
ecu p07-a01 80
ecu pt2-a12 50
