JDM engine /usdm ecu
Old Nov 21, 2011 | 06:39 PM
b18c5 power's Avatar
Default JDM engine /usdm ecu
Would running my usdm ecu damage my jdm engine ! After tuning something went wrong i`m still in a jam , my chipped ecu does not run the car properly anymore(run fine for a week) ! IT`s the chip or ecu or both! I`m in the process of getting a new ecu/ ship !!! With the usdm ecu it run fine but, i think i should be careful !
Old Nov 21, 2011 | 07:00 PM
yungkhmer's Avatar
Default Re: JDM engine /usdm ecu
Will be fine. As long as it matches the motor itll run.
Old Nov 21, 2011 | 07:24 PM
racebum's Avatar
works fine. the jdm and usdm engines are so close to identical as to not be an issue. it's literaly .4 point of compression, nothing else. damn stock p73s are tuned so rich as it is you're not going to have a problem
crazihobo
Nov 5, 2008 09:57 AM
Jonovision
Aug 4, 2008 02:29 PM
broken_machine
Mar 26, 2004 08:17 AM
ptsiu
Nov 30, 2003 11:28 PM
