FS, Eagle Rods, Z6 Block, Cranks, ZC trans, SI trans Clutchmasters etc
Old Nov 21, 2011 | 05:56 PM
914Racer's Avatar
Default FS, Eagle Rods, Z6 Block, Cranks, ZC trans, SI trans Clutchmasters etc
Alright, gotta fund my GT3 car and need to clear out my D series bits. I bought these parts to use in the GT3 engine, but I am going to have more success with a B16
Parts are located in Huntsville AL
Here is what I have:
Apexi VAFC $75
Eagle H-beam rods with ARP 2000 rod bolts: $200 shipped OBOSold
DC Sports Stainless 4-2-1 header fits 88-91 CRX/Civic, Should work on an
EG and others. $150 OBO
Thermal R&D CL Stainless Exhaust for CRX. Still on the car but the car hasn't left the garage since I started working on it a year+ ago.This is a 2.25in diameter. Works good on a D16. $250
Clutchmasters Aluminum Flywheel: $150 shipped
ZC Transmission with halfshaft and axles. Worked great on my turbo car. Insides are spotless. Was going to keep it for a custom gear box but swapped to a CG trans instead. This would be excellent for a custom gearbox. ; $200 + shippingPending
Cable Si gearbox : $150 OBOPending
Cable Si gearbox, needs bearings. Would be a perfect swap for the ZC ring and pinion. You could have a short geared street box with little work.Pending
Complete D16A6 long block, great start for a ST autox car or an IT engine. $75
(3) D16 factory crankshafts. All standard, in perfect shape. $50 each
1 D16Z6 Block. Stock bore, block is in excellent shape. 5lbs lighter than your A6 block. $100 OBO Sold
D16Y8 Vtec head complete with valve cover, cam, rockers, etc. $100
D16Z6 Head complete with cam, valvetrain, and valve cover $100 Sold
D16Z6 Valve cover $10sold
Stock EF Civic Axles. I have 3 pair. All appear to be Honda axles not remans. They also have the stock rubber damper required for SCCA. $20 a set.
Stock D16A6 intake manifold, complete: 10$
D16A6 Pistons and rods. New bearings. 20$Sold
Wilwood Prolite 6R Calipers and New Pads: $500
1.033 4th gear set. Great upgrade to the SI box listed above. Get a nice short fourth gear. Fits all cable boxes. $100 OBOSold
Huge pile of L3 cable transmission parts. Too many to picture. Sold
Too lazy to pull the exhaust off the car yet. Just took a picture from Thermal's website.
Old Nov 24, 2011 | 09:52 AM
B1rdMan86's Avatar
Default Re: FS, Eagle Rods, Z6 Block, Cranks, ZC trans, SI trans Clutchmasters etc
do you still have the z6 block?
Old Nov 24, 2011 | 11:45 PM
CivicTTurtle's Avatar
is the y8 head still available? if so PM me, or email me. shieldsej@hotmail.com
Old Nov 26, 2011 | 04:25 PM
914Racer's Avatar
PMs sent.
Old Nov 26, 2011 | 09:38 PM
0bd1_Kanobe's Avatar
How much for the d16a6 shipped to 85607 area
Old Nov 26, 2011 | 11:33 PM
sohcturbo92vx's Avatar
Can u pm me if u have a good z6 crank
Old Nov 27, 2011 | 03:24 PM
markymark885's Avatar
ill take the VAFC just sent you a reply to your email
Old Nov 27, 2011 | 04:28 PM
Payment sent for VAFC
krazye419
Apr 14, 2012 04:51 PM
MRN1120
Northeast (Sales)
14
Jun 24, 2009 06:30 PM
MRN1120
Mid-Atlantic (Sales)
10
Apr 5, 2009 06:07 PM
MRN1120
Mar 29, 2009 05:22 PM
ef8
May 3, 2007 02:11 AM
