Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Washer Fluid HELP!
Old Nov 21, 2011 | 12:48 PM
PA2011's Avatar
Icon2 Washer Fluid HELP!
I have a 2002 Odyssey and the washer fluid wont spray (yes, it is full of fuid). the controller arm for the wipers will control the wiper functions, but when pulled back for windshield cleaning, nothing.
Any thoughts?
Old Nov 28, 2011 | 09:09 AM
NDNV's Avatar
Default Re: Washer Fluid HELP!
Check for a kinked washer hose under the hood.
Old Nov 28, 2011 | 05:18 PM
lazlong's Avatar
Do you hear the washer fluid motor turn on when you pull the switch?
Old Nov 30, 2011 | 01:18 PM
boostinCX's Avatar
I have the same problem with my 2002 MDX, full of fluid, and wipers do their thing but nothing sprays onto the windshield... haven't figured it out yet. I have followed all the lines and no kinks that i can see. Maybe the pumps are going bad?
Old Nov 30, 2011 | 07:28 PM
lazlong's Avatar
Have a friend pull the washer fluid switch while you listen near the fluid tank. You should distinctly hear the fluid pump turn on. If it doesn't you'll need to find the fluid pump and test for voltage at the wire side of the pump connector while your friend pulls the switch. If you have voltage then the pump is bad. Usually it's on the bottom of the tank and you have to take the plastic inner fender off to access it.
Raguillon
Nov 12, 2013 02:06 PM
david420
Sep 9, 2010 06:48 PM
double11
Honda Fit
Aug 6, 2008 11:46 AM
HanSnobbler
Jul 22, 2005 08:14 PM
mingbling
May 17, 2004 09:36 PM
