need axles
http://www.driveshaftshop.com/
http://www.raxles.com/ordering.aspx
'Stage' is a nonsensical term used by those who play too much Gran Turismo. It has no finite meaning.
MAD_MIKE has you covered with a few options, though I'm concerned that you have such a built motor, yet are lacking knowledge about something that's frankly much simpler than the engine.
Check out the Forced Induction sub-forum and do some research if you haven't already. I think you'll find that just because you are making turbo power, doesn't mean you always need to go with aftermarket axles (and the problems that come with them).
Plus, you might find more detailed and more relevant answers more quickly by searching. Good luck!
https://honda-tech.com/forums/showth...ighlight=axles
If you read through it, you'll have an answer.
ii ok i look n wonder would this axles would be good http://www.driveshaftshop.com/import...t-hasport-ekh2
Originally Posted by Drivshaft Shop
Honda Civic EG/EK ...
OG undercover
Dec 16, 2006 06:22 AM
