I am using a GSR harness in an EK, anyboby else done this yet?
Old Nov 21, 2011 | 12:47 AM
ssmtyper's Avatar
Default I am using a GSR harness in an EK, anyboby else done this yet?
I am currently combining the engine wireing harness from a 97 GSR and a 97 Civic because as i was getting ready to put the Gsr swap in the Civ, I decided i didnt want to use the old shitty DX harness an have to add the Vtec knock, etc...
So i went to a guy here and got a EX harness, problem solved right? well wrong turns out the ex harness has a few missing clips and several other clips are broke.....
Well my plan for this car is for the swap to be STUPID clean, and look like it came that way from Honda even to a trained or semi trained eye, lol...
I have the whole Gsr car as i bought it wreck specifically for the swap, all original DC2 unmolested (besides a fair amout of drivers rear body damage) So i start thinking, why dont i just use the harness from the GSR, its in PERFECT condition, and couldnt possibly be all THAT diffrent....
Well I was wrong! it is VERY diffrent in many many ways, i sort of go back and forth with myself trying to convince/talk out of going for it....
I am now about 40% there after just one day of hacking the harness outta the GSR and getting all my diagrams straight, depinning and repinning the engine-to-under dash section, and getting a very solid outlook on the path to finishing it tomarrow... I am around 80-90% sure at this point it will work just fine AND i will have the benifits of an OEM engine harness, and the ability to disconect in the engine bay instead of pulling through the firewall....
I will get some pics and more info up in the next couple days as I have not found a single other person who has ever even attempted this...
I would NOT recommend this to anyone unless you have a WHOLE parts car and you are VERY confedent with wiring and reading wiring diagrams!
P.s. i am new here to Honda Tech, hate on me if u want, i already know there are much easyer ways of going about this but whats the fun in being the same as everyone else?
Old Nov 21, 2011 | 01:05 AM
ssmtyper's Avatar
Default Re: I am using a GSR harness in an EK, anyboby else done this yet?
OH and i also realize no one will belive me till i post pics and vids of the work and it running... its coming just wait.
Old Nov 21, 2011 | 04:20 AM
jdmkid1989's Avatar
waiting on the pictures
Old Nov 21, 2011 | 05:31 AM
94EG8's Avatar
Seagull Management
One of the benefits of the EK harness was that it goes straight to the ECU. You can build the whole harness out of the car on the workbench instead of being jammed up under the dash trying to run the vtec wires through the firewall.
There's just absolutely no good reason to do what you're doing. To wire vtec on a Y7 harness is 3 wires and then 1 more for knock. I'm not saying it can't be done but it's just a lot of extra work with absolutely no benefit.
Old Nov 21, 2011 | 06:46 AM
crx_si-r's Avatar
if you need a harness i can build you a brand new one. ive made tucked EK OBD1 H22 swap harnesses before. feel free to check out my sig below for pics and video of my work.
here is a youtube video of the h22 ek tuck harness, the customer of this harness wanted RDX injectors and obd2 injectors and distributor. enjoy
http://youtu.be/4OOTtGMMlng
Old Nov 21, 2011 | 06:47 AM
crx_si-r's Avatar
also you will have to do a lot of rewiring to get the GSR harness to work on an EK, seeing as the routing of the both GSR and EK are very different.
Old Nov 21, 2011 | 10:48 AM
ssmtyper's Avatar
Your right there is no real good reason to go this route for almost anyone... For me I am VERY **** about things looking and being very legit, so the way i see it is if i I am going to run 3 for vtec, 1 for knock, convert the 3 wire IAC and 3 wire CFS, run wires for the IAB, and still have to extend some other wires to reach, My OCD mind would not allow me to just "throw" them in there and tape them to the loom.... I would want to pull the harness apart and run them as OEM would... if im going that far anyway i may as well give this a shot...
Also I am not a fan of the tucked bay look, but still want it to look nice and clean so the best way to do that is use the harness that is made to do just that...
Also like i said in the OP, "I know there are much easyer ways to go about this." It all comes down to my "ocd" Not to mention i like the challenge of doing something, that as far as i know has never been done..
Any Idiot can read a "how to swap" guide and do it just like every other Xerox Civic out there...
Old Nov 21, 2011 | 10:52 AM
ssmtyper's Avatar
Oh and I am NOT working under the dash that would just be dumb, and I am building the harness still straight to the ecu... hard to explain, ill get pics up here this evening with markings to explain better
Old Nov 21, 2011 | 11:43 AM
crx_si-r's Avatar
Also by using a GSR harness you will also need to re rout most of the wiring from the ecu to the driver side. On a GSR harness you have the following sensor wires on the driver side:
Evap
Vss
Alternator
Iacv
Rpm
Starter
Distributor power source
And many others that an EK routed on the main harness (passenger side) wiring
Old Nov 21, 2011 | 12:39 PM
ssmtyper's Avatar
yeah i have figured that out, I am sure in the long run I will see all this was really overboard, but for now, its not costing me a dime and i am enjoying the challenge...
I am uploading pics now and will post shortly with the progress thus far...
Old Nov 21, 2011 | 12:57 PM
ssmtyper's Avatar
The GSR lower harness chopped out of the car and plugged into the ECU, this is when i was figuring how to attach the green connector from the EK harness than plugs under the EK dash.
This is the GSR lower harness with the Green EK plug unpinned from the EK harness and repinned to the GSR lower harness...
GSR engine and lower harness with Green EK plug added... still some figuring to do but have a real strong vision of where its going...
The original DX harness, I am keeping this one whole just in case LOL...
Old Nov 21, 2011 | 01:01 PM
ssmtyper's Avatar
sorry they are kinda shitty pics, all i have is my phone.
Old Nov 21, 2011 | 01:31 PM
crx_si-r's Avatar
That green plug is going to eliminate most of the driver side shock tower plugs from the GSR harness. That's why it doesn't make sense to add in all the extra wiring. I'm assuming of course that you will be running new wiring from the driver shock tower plugs (the ones that's weren't there before) to the green plug by the ecu
Old Nov 21, 2011 | 01:49 PM
ssmtyper's Avatar
yup you nailed it thats the track im on, I am tracing down all necessary wires from drivers GSR section and rerouting as necessary... Have you attempted this or done this before? seems like you are right on "my page" with whats going on... Bless Mitchell on Demand for wiring schematics LOL
Old Nov 21, 2011 | 01:55 PM
ssmtyper's Avatar
techically though there are only two wires from the green plug that didnt repin and thats VSS and PSPSS
Old Nov 21, 2011 | 01:58 PM
crx_si-r's Avatar
I make swap harnesses from scratch. So I know which wires go where. I have made a harness from 88-00 civic/crx and 90-01 integra. From stock replacements to swap harnesses.
Old Nov 21, 2011 | 02:00 PM
crx_si-r's Avatar
You will still need to run the vss wire to the driver shock tower. As well as the power for the speed sensor
Old Nov 21, 2011 | 02:58 PM
ssmtyper's Avatar
awesome! thanks for the info! now i know who to hit up if i get stumped lol
HondaCityEK7
Jul 16, 2008 05:02 PM
kasperxtcy
38
Dec 28, 2007 10:49 PM
eknorcal
Nov 14, 2005 10:23 PM
shadykit
May 20, 2004 05:28 AM
Homericaeast
May 7, 2002 04:08 AM
