97 accord ex vtech 5spd trouble staying on
cranking over stays on about maybe like three minutes then idle will drop an shut off. I try pumping the gas an wont stay on. I don't know were to check if it fuel regulator or in the ignition. I don't know what could it be maybe also the throttle body position sensor could be a factor???
no codes or check engine light i don't know its when i start it when engine cold it will be fine till like three minutes it will choke shut off i tried to rev it but won't do anything
i had a similar problem in a crx, turned out to be the distributor... sounds like something electrical/a sensor since its starting and then dieing but could be other things just have to do troubleshooting like comp test, look for corrosion, test alt, timing could be off, check injectors ect.
giovannie23
Jul 2, 2014 08:18 AM
redheadcivic
Jun 1, 2004 11:00 AM
