99 Civic vtec not engaging
Old Nov 20, 2011 | 06:51 PM
Got..BOOST??'s Avatar
Default 99 Civic vtec not engaging
Vtech kicks in when you ease into it but when u go past 1\2 throttle cel comes on car starts bogging out and once in a while shuts off help
Old Nov 20, 2011 | 06:58 PM
Jdubbs6101's Avatar
Default Re: vtech not engaging
What's the CEL did you check it.... Do you know how to check it..
Old Nov 20, 2011 | 07:01 PM
civicStyle's Avatar
vtec isnt a phone first of all. and second, what code are you throwing. it could be you tps sensor from the sound of it. but can be other things.
Old Nov 27, 2011 | 11:38 PM
The cel only stays on for a second
Old Nov 27, 2011 | 11:54 PM
Dioxine's Avatar
Really only checked out this thread to see how many people got mad at how vtec was spelled lol. But your problem does sound like the wires are crossed on the tps or the tps is going bad. And if the cel comes on at all the ecu should store it to be checked later so jump the diagnostic port and pull it. I believe that tps is 17.
Old Nov 28, 2011 | 01:29 PM
Default Re: 99 Civic vtec not engaging
Went to get the code and the cel stays on no flashing wtf do I do
Old Nov 28, 2011 | 01:55 PM
grumblemarc's Avatar
The Grumpiest
Not a good sign. Have you tried resetting the ECU?
Old Nov 28, 2011 | 02:10 PM
How??
Old Nov 28, 2011 | 02:21 PM
Dioxine's Avatar
You can pull a fuse im not sure which one it is though and wait ten minutes. Or you can disconnect your battery for no less then 10 mins (this is what i always do)
Old Dec 3, 2011 | 09:53 PM
Tried resetting the ecu but didn't work changed the tps and that didn't work. Now im waiting on my s300 ecu to come back and see if that fixes it
Old Dec 3, 2011 | 10:28 PM
Texas4door's Avatar
You say you changed your TPS sensor?
...did you recalibrate it when you did?
(and are you sure you changed your TPS, cuz the bolt heads for the thing are taken off at the factory when it's installed on the throttle body so the calibration doesn't get screwed up)
...this may sound stupid, but have you checked your MAP sensor to see if it's crapping out?
(also to make sure you didn't switch the MAP and the IACV plugs for some weird reason, as they ARE the same plug shape)
...then again in that case, your car would idle like hell...
Good luck!
Old Dec 4, 2011 | 06:23 AM
It has an aftermarket throttebody and the tps and the map and iacv are connected correctly
liquidxEG
Feb 22, 2005 03:46 PM
SearchBeforeUPost!
Mar 31, 2004 06:54 PM
SearchBeforeUPost!
Mar 31, 2004 05:39 PM
-Whitey-
Feb 3, 2003 02:39 PM
Rhetoric
Jan 2, 2002 01:10 AM
